Few items up for sale. Contact: 0433 220 four four nine
1. Garrett T04R Turbo (aka T66 from GCG turbos over east)
- Absolutely No Shaft Play
- T4 flange entry, V band exit on turbine housing
- 0.84A/R turbine housing
- Journal Bearing
- Comes with feed oil line
- Comes with flange and pipe that bolts into the compressor outlet
- CHRA S/N: 60189
- CHRA P/N: T66-PSB360TH
- 700 hp (@ engine capable)
Nissan RB25 Manifold
- China stainless steel manifold from ebay
- T4 Flange
- 38mm external gate exit
PRICE: $900 Firm ($1000 if bought with the wastegate below)
NO SEPARATES, I don't have a use for the manifold if the turbo sold by itself.
2. Garrett GT35R Turbo Brand New Genuine
- In box with manufacture warranty, has NOT even been trial fitted or used in any way
- Compressor wheel is the next generation Garrett CNC machined wheel (lighter than the inconell cast for faster response)
- Turbine Housing: T3 entry, 4 bolt 3" GT exit, 0.82A/R
- CHRA part no: 714568-5002S (112682-27)
- Comes with all gaskets required to fit it from factory
This exact same unit will cost $2200 from MTQ or Turbotech. My loss, your gain. Decided it was too big and unresponsive for 2L.
PRICE: $1800 Firm
3. 6 x RB25 Side Feed Injectors JECS
- Removed from a running engine when decided to go bigger for higher HP on E85
- About 6000kms on it
- Comes with injector data sheet (flow tested and matched at certain pressure and latency etc)
- JECS High Impedance Side Feed Type apparently good to run E85 (270kw limit) as well
- Drops right in to stock RB25 (non neo), SR20, VQ35 and VG30 fuel rail. May fit subaru motors as well (do your own research)
- Good for about 600rwhp on 6 cylinder engines running on petrol with plenty of safety head room
PRICE: $500 Firm
4. For Sale: 6 Puck Clutch to suit RB20, RB25, RB26 (push style) and RB30
- Brand: SPEC America
- Capacity: 600NM
- Type: Single Plate 6 Puck Push Type
This clutch was used for about 1200kms in which was driving the R33 down to bunbury twice to break the new built engine in (no high revs no limiter bash no clutch kicks or dumps). Now plan has changed to push big torque with the RB30DET so decided to change to a twin plate.
Have this exact same clutch on my 400rwhp 470nm RB25 R32 with 4 years worth of drift pracs and comps, rallysprint, no limits events and speed event series with absolutely no fault. This clutch just loves abuse and pedal feel is great (no overly heavy).
PRICE: $300 Firm
5. 50mm Synapse Synchronic External Wastegate
- Used but great working condition
- V band entry and exit HOWEVER, I welded a tube reducer with a flange to suit 38mm manifold exit. If you have 50mm manifold wastegate exit you may simply cut out the reducer I made and utilize the v band.
- Comes with the screamer pipe
PRICE: $150 Firm
6. HDI Electronic Boost Controller
- Perfect working condition, comes with solenoid and wiring harness
- Simple electronic boost controller and holds the desired boost dead flat
- No finniky settings dial to make it work right (i.e HKS)
(Pic displayed is from the internet but it is the same thing)
PRICE: $70 Firm
7. R32 Skyline Passenger Side Coupe Quarter Glass, exterior seal is still intact
PRICE: $70 Firm
8. Blow off valve
Unsure what brand it is but looks like turbosmart. Adjustable spring pressure by twisting the head. Good working condition, NON-gay ricer sound or Habib spec that wakes up the whole suburb.
(Does not come with the intercooler pipe)
PRICE: $50
9. R33 S1 Front Bumper
- Painted red by drunk mates
- Has the intercooler cut out
PRICE: $20
10. R33 S1 OEM Bonnet
- No dings, painted metallic black
PRICE: $50
And again, contact is 0433 220 four four nine
Beeliar S.O.R
Edited by kliono
  • 1 month later...
I purchased a Garrett Gt35R brand new not long ago for $1400. Yes it's genuine. You got a bit ripped off...
    • Hello, just just bought an 1999 enr34 with a stock rb25neo and I'm looking to upgrade the engine to 500whp I know some basic things but wondering if there are things I'll need to do to upgrade the stock block and all the bits and pieces to achieve this.
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
