Hey Guys,
I've just pulled down my engine and found that its running N1 pistons - p/n A2010-AA472 and my piston to bore clearances seem fairly large. On average i'm seeing about 0.113-0.115 clearance.
I know the factory recommendation is 0.035-0.055.
What do you guys usually run on rebuilds? should i be concerned with such large clearances?
Thanks in advance.
https://www.sau.com.au/forums/topic/445895-rb26-piston-bore-clearance/
Are you talking thou or mm when you are measuring? Because if you are measuring in thou then the nissan spec is most likely mm in which case you are on the lower end of the tolerance
Edited by 89CAL
Id say your talking mm there, so factory would be 1.5ish to 2ish thou clearance, so in that case you have about 4 1/2thou which is a lot for a cast piston.
Did you have much piston slap and blow by when it was running?
Edited by AngryRB
i'm talking mm.
all measured up with micrometer.
No catch can, only a slight film of oil on the intake pipework when stripped down, never used oil and the engine wasn't loud or out of the ordinary. It was running like this for about 6 years making about 270-290kw
I'm alittle stumped by these measurements.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
