Been holding onto this for awhile as I couldn't bring myself to sell it off knowing il probably never see one again. Anyways
Garrett gt3076r .063 ceramic coated ex housing, surge ported comp housing.
As new condition, bearings are smooth and silent and zero endplay.
Cast iron twin scroll hks low mount manifold to suit rb20/25, ceramic coated chrome.
Matching hks 38mm external wastegate which I believe has 14psi springs in it.
3 inch dump pipe running to cat and a 1 inch screamer pipe setup also.
Also have brand new in the bag fitting kit from gcg which includes turbo to manifold and turbo to dump pipe gaskets.
Also have a billet oil drain fitting and length of oil drain hose all brand new still with gaskets.
Also have the block water and oil adapter fittings.
And a silicone 4inch to 3inch reducer, a straight 4 inch silicone hose and a turbo outlet reducer hose all in black, brand new.
Pieced it all together to make the most of a standard internals rb25 but I can't see myself making use of it any time soon so il let Somone else enjoy it.
I'm aware of how rare and sought after these cast iron low mount manifolds are so
Wanting $3100ono for everything listed above.
Located an hour out of Adelaide and can post at buyers expense.
Can text Tom on 0423420713 for more pics or details.
-Also worth noting the dump pipe was made for my rb25/30 in cefiro, so due to the added block height of the rb30 you may get away with it fitting up fine but possibly would only need cutting shortening by 38mm.
    • Holy smokes brother. If you get there before me, let me know if that was manageable with a hone. I still haven't done anything with mine and probably won't until I get the car MOT'd later this year so that I have another 2 years to do what ever needs to be done. I am at 86.5 now so at least I have the 0.5mm to go up from where I am, but that means new pistons at the very least. Honestly, might consider a stroker at that point.  Cheers
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
