SO I have a platinum pro and are looking at going flex and stumbled across some American forums that had you can use the GM sensor, you just need to change the plug:
Use a GM flex sensor
Part # 13577394 (long tube) $66 or
Part# 13577379 (short tube)
Either buy the GM Harness and rewire Part # 13352241
or buy the plug and pins yourself
Now they look exactly the same and works out to be a lot cheaper, apparently both are 50-150hz.
Pic below.
Can anyone confirm this
HT011000
F60482058
The other side is that a guy in the states is running this sensor and instead of using a IO expander, he is using a zeitronix ethathnol gauge to convert the signal to a linear 5v signal.
He then inputs that signal into the spare AVI.
The sensor also reads fuel temp, so you use the other AVI to read the fuel temp......
I wouldn't be surprised if they are rebranded GM sensors - Their external MAP sensors (4-5 bar) which I have are "GM" ones or "Haltech" ones depending on who you ask.
I have the haltech one, and happily paid the extra to make sure it worked.
I wanted to peel the sticker off to look more 'factory' but never did it. Maybe I'll do it and see if the PN under the sticker is there/the same.
So basically this is very doable.
Zeitronix gauge is $200
GM Ethanol sesnsor and wiris $80
This issue I have run into, is that my dual widebands occupy my AVI inputs into my haltech. So looks like I will have to get the exander box regardless.
If I had the newer CAN widebands.... good to go on the flex set up I have described, as the newer dual bands use the CAN input and not the AVI slots.
You have a couple of options.. Go the Zeitronix unit and use 2xAVI's on the Haltech, but by this stage you have spent $500 and have used up 2 valuable inputs (if you have them spare - if not Haltech can mod the AVIP inputs to act as regular AVI's if you have those spare)
Haltech sells a CAN IO Expander Bundle with Flex sensor for RRP$599 (haltech part HT-059906), slightly more expensive but the IO box gives you plenty of extra IO should you need it down the track (fuel/oil/coolant pressure sensors, extra temp sensors etc). You also only use a single digital input on the Haltech to get both Ethanol Content and Fuel Temperature. :cheers:
Most ecu's can get away with using one input, ditching the fuel temp input. It would be nice to have, but surely you have one spare 0-5v input... It depends how you want the tune done, and how hard you plan to push it I guess
Personally I would just run dual maps as there is less chance of a failure. It's not like you will ever run petrol again once you convert. :P
  • 2 years later...
I have been told that gm is the only manufacturer of fuel flex sensor and any others are just rebranded gm products.
That would be correct, but I believe continental is the manufacturer. Siemens also makes flex sensors of a different type. At the end of the day make sure you buy one from a reputable source, i bought one off ebay that was meant to be of good quality but was no good. I then got one through nistune.
  • 4 weeks later...
    • Welcome Thomas! Sounds like you've made some progress. Are you able to drive it and enjoy it a bit now ?
    • HUMVEE are fine in big open areas, but they are problematic on the street and tight areas As for reliability, some of the  US Army guys I have chatted with have said that when they were working they were fine, but, the do spend alot of time in workshops for multiple reasons, admittedly, they did get a hard time by the boys and girls who drove them I would definitely put them in the "buyer beware" category  They do look tough as nails though
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
