SO I have a platinum pro and are looking at going flex and stumbled across some American forums that had you can use the GM sensor, you just need to change the plug:
Use a GM flex sensor
Part # 13577394 (long tube) $66 or
Part# 13577379 (short tube)
Either buy the GM Harness and rewire Part # 13352241
or buy the plug and pins yourself
Now they look exactly the same and works out to be a lot cheaper, apparently both are 50-150hz.
Pic below.
Can anyone confirm this
HT011000
F60482058
The other side is that a guy in the states is running this sensor and instead of using a IO expander, he is using a zeitronix ethathnol gauge to convert the signal to a linear 5v signal.
He then inputs that signal into the spare AVI.
The sensor also reads fuel temp, so you use the other AVI to read the fuel temp......
I wouldn't be surprised if they are rebranded GM sensors - Their external MAP sensors (4-5 bar) which I have are "GM" ones or "Haltech" ones depending on who you ask.
I have the haltech one, and happily paid the extra to make sure it worked.
I wanted to peel the sticker off to look more 'factory' but never did it. Maybe I'll do it and see if the PN under the sticker is there/the same.
So basically this is very doable.
Zeitronix gauge is $200
GM Ethanol sesnsor and wiris $80
This issue I have run into, is that my dual widebands occupy my AVI inputs into my haltech. So looks like I will have to get the exander box regardless.
If I had the newer CAN widebands.... good to go on the flex set up I have described, as the newer dual bands use the CAN input and not the AVI slots.
You have a couple of options.. Go the Zeitronix unit and use 2xAVI's on the Haltech, but by this stage you have spent $500 and have used up 2 valuable inputs (if you have them spare - if not Haltech can mod the AVIP inputs to act as regular AVI's if you have those spare)
Haltech sells a CAN IO Expander Bundle with Flex sensor for RRP$599 (haltech part HT-059906), slightly more expensive but the IO box gives you plenty of extra IO should you need it down the track (fuel/oil/coolant pressure sensors, extra temp sensors etc). You also only use a single digital input on the Haltech to get both Ethanol Content and Fuel Temperature. :cheers:
Most ecu's can get away with using one input, ditching the fuel temp input. It would be nice to have, but surely you have one spare 0-5v input... It depends how you want the tune done, and how hard you plan to push it I guess
Personally I would just run dual maps as there is less chance of a failure. It's not like you will ever run petrol again once you convert. :P
  • 2 years later...
I have been told that gm is the only manufacturer of fuel flex sensor and any others are just rebranded gm products.
That would be correct, but I believe continental is the manufacturer. Siemens also makes flex sensors of a different type. At the end of the day make sure you buy one from a reputable source, i bought one off ebay that was meant to be of good quality but was no good. I then got one through nistune.
  • 4 weeks later...
    • Getting Dangerously close to being ready to go back in the car. Rockers in with clearance castings now (and a quick check with the USA for the torque settings for the larger custom bolts) Covers and ported FAST Manifold sitting on there. Not fully tightened down as there's some clearancing required for the water pump with the earlier LS1 water pump styles. Example of the clearancing needing to be done: The body has to be ground a little but I'm struggling finding an actual piece of it. The later variant of water pump resolves the issue as the manifold was designed around it. It only came on the VZ LS1 in Australia, it got a different pulley for Gen4 motors. (it also costs $450... vs... $0).
    • https://files.fm/f/5atwkuvcjd
    • Doing some height adjustment on front suspension on a v35 and noticed this. The passenger side looks correct. So wondering what's happened to the drivers side?
    • Oh...I have the electric mirrors as well iirc ...they're in the same state as just about every other R31 door mirrors, with the 3 plastic screw towers broken/cracked in the plastic molding. All the interior is 'dry', so the mirror switches etc likely all work fine. Some pics below of the trimmer pieces ~ looks to me like previous owner, painted chrome finished trims with black paint ...ergo, the chrome underneath is likely a-ok... ...starts to look yukky posting stuff like this, how much did it cost in fuel on your last sortie up this way?...me just thinking aloud, borrow someone else's 4cyl to cut costs, come do your own pick'n'pull like before to save me some bother...hehe.. but whatever, I'll just earmark bits I know you want, because the way this is all panning out, I'll be able to retire the R31 from daily duty at long last, replacing it with a Subaru wagon I'm lining up in the wings...ergo, my attitude towards the donor pinny shell is starting to wane a bit, and I'm more than happy to help you out there... Like you say though, no rush...and I'll guarantee we won't be moving too far from this locale at any rate 😎
    • Cool, I’m just down Sydney today. Not much time to get online.
