I recently purchased a 92 R32 GTS-t and have spent some money cleaning it up. Now i am keen to add a bit more power to it but i have a few questions since the car has a few aftermarket bits which i'm not 100% sure on just yet as I am new to turbos. So the car has Power FC, RB25 Turbo with 360 degree thrust bearing, Split Fire Coil Packs, 550 cc Deatschwerks Injectors, Stainless Braided Oil Water and Break Lines with Speed Flow fittings , Front mount Intercooler, HKS Turbo Timer with auto meter boost gauge. The previous owner had the boost put up to 13psi and tuned but then took out the manual boost controller (So is that running wastegate pressure?) and had it retuned for 8psi.
Okay so now my questions.
So if I wanted to up the boost would I be able to reinstall the manual boost controller and put it up? (How do I know how much is too much boost when turning it up?)
OR
Would I need to take it in to get retuned before I touch any boost levels?
Also what is a "HKS Turbo timer with AUTO METER BOOST GAUGE" I know what the turbo timer is but what's the auto meter boost gauge?
Thanks for helping me learn guys
Angus
https://www.sau.com.au/forums/topic/445949-help-me-up-the-boooosst/
If you do decide to get a boost controller, limit yourself to 10-12psi to keep it safe. Then get it tuned if you want more.
This is an Auto Meter Boost Gauge.
So Auto meter is just a brand as such? Yes i have that boost gauge in the car still, I think I might reinstall the boost controller (it's just sitting in the glovebox at the moment haha) and only go up a little bit just to be safe
Yep, Auto Meter is just a brand of Gauges. ^That's the exact one I run in my car.
You should be fine to wack the boost controller back in. Just make sure you stick it in the right hose and keep an eye on how much pressure it's making.
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
