On my way to work this morning I got hit with some school traffic and decided to find an alternate route, and I found a cracker of a road (even if it is only a short one).
The road was a bit wet this morning from some light showers overnight, and with some multiple surfaces it creates some unexpected surprises.
Please note that this review is taken within legal road limits. I do not encourage 'hooning' or performing illegal acts on public roads. Please respect the road rules at all times and take note of advised speeds (marked in yellow) before making your own judgement.
Protheroe Rd - Forgan Rd, Cashmere (Speed Limit: 80kph)
When heading from Protheroe Road, the first left hander (40kph) is slightly banked and has an open rough asphalt surface. The apex of the corner doesn't have much grip when wet, so be careful not to hit it too quickly. As the road opens you get a nice high speed winding section up to the top of the hill before a set of blind esses (50kph) dropping down a 16% grade. The esses tighten and open up again, but be careful not to tackle too quickly as there is a solid concrete gutter on the outside that's going to make a mess of your rims if you come over the crest with too much speed. As you arrive at the end of the road keep to the inside line - the road narrows over a blind crest with loose gravel on the side of the road.
If you have any good cruise roads please share them. I'll endeavour to keep updating this first post with your favourite roads to make it easy for everyone to find them.
Edited by Simink
https://www.sau.com.au/forums/topic/445962-good-cruise-roads-in-se-qld/
I drive this section of road regularly, it's ok but there are much more fun roads around ;)
Haha, yeh definitely. Wouldn't go out of my way to sight this one, just an alternative to boring ol' Youngs Crossing! Thought it might be a good idea to start sharing these by starting with a nice little one to gauge interest.
Be good to eventually pull a map together of good drives that we can link up. My brothers and father are really into bikes. They have an awesome layout they go cruising on throughout the Sunshine Coast hinterland. I'll try to map it out sometime. It's at least a 90min loop.
The ultimate cruising road would have to my the Mt Lindsey highway through the bellbird ranges, between Rathdowne and the Kyogle turnoff (following road toKyogle isn't bad either). A lot of people take the Lions road instsead, but honestly i think the main road is better.
The road from Kyogle back to the coast isn't a bad drive either, but last i was there the surface was terrible.
Its a long way from anything though.
Thanks Pete, I'll add it :)
Mount Lindesay Highway, Rathdowney - Lindesay Creek
Submitted by 'sneakey pete'
The ultimate cruising road would have to be the Mt Lindesay Highway through the Bellbird Ranges, between Rathdowney and the Kyogle turnoff (following road to Kyogle isn't bad either). A lot of people take the Lions Road instead, but honestly I think the main road is better.
Thanks Cadmoon, that one looks like a cracker! I'll add it (with a finishing touch from Mount Mee into Dayboro - been on that drive before, it's pretty nice)
The Gap - Mount Nebo - Mount Glorious - Kilcoy - Woodford - Mount Mee - Dayboro
Submitted by 'Cadmoon'
Mt Nebo, Mt Glorious, out to Kilcoy then back via Woodford and Mt Mee...
Edited by Simink
This is the better version of this road, starts at the bottom of Mt Nebo
Cheers. Updated using Google Maps Engine. Anyone using Google Maps on their phone should be able to save it as a GPS route.
Here's a loop I'm going to check out this weekend up in the Sunshine Coast Hinterland. If you're ever doing a cruise up that way I highly recommend planning a stop at the Mary Cairncross Cafe, especially on early morning winter drives. They do massive awesome breakfasts, and have a big fireplace burning in the middle of the cafe. Toasty! Been up there a few times when it's been wet and the mist looks amazing. Would make for some good photo ops.
Sunshine Coast Hinterland loop
These link open up nicely in Google Maps app, but how to do save the Map.
I'll have to convert the others to a Maps Engine Map, but you should be able to download 'Maps Engine' app for your phone, log in to your Google account and load a saved map, then hit Directions to start navigation.
To create maps for the Maps Engine go to https://www.google.com/maps/myplaces, create a map, then save it.
Let me know if you can save the Mt Nebo route to your own maps, if not I'll have to set the permissions to allow everyone to edit them.
  • 3 weeks later...
Yes, many many goods roads are up out north east of Brisbane. Be careful though as motorbikes, police and trucks can appear so always keep well within the limits and on your side of the road.
    • If you want to do the wiring, the GTT engine ecu has the same pinouts extra that the seperate TCM in the NA car has. You can literally grab the wires/pins that lead into the Seperate TCM and wire them into the corresponding pins in the GTT Engine ECU. You could then in theory Nistune it. I realised this when everyone put it in the too hard basket and I actually looked at the f**kin R34 manual. This is after I had previously had a seperate aftermarket TCM controller in my original N/A chassis car and a very built gearbox from a GTT, running a seperate Haltech engine ECU. I ran into this issue when I re-shelled the car into a GTT shell, so my aftermarket TCM was no longer plug and play, because the loom/modules were not present. I was pretty livid when realizing just how simple the original fix actually was. It sat for 3+ years at various workshops trying to find a solution. In practice none of this is a worthwhile idea for a lot of reasons, generally surrounding the shitness of the NA auto, the autos in general that come with skylines, and the NA engine and lack of gains. The gearbox is specced for the 2.5L N/A and barely at that level. If you have to pay anyone any money to do any of this, that is money spent on manualizing the car and it's not even close in terms of a comparison. Learning to drive manual is simpler than going through the pain of dealing with the N/A gearbox and he'll have fun to boot.
    • Semi-correction to my blanket statement that you can't bend rubber hoses. It seems that you can get most of a result, by doing as this guy does. I wouldn't promise that the bends will stay in the hose forever. I think if I found they wouldn't stay, I'd get a larger hose and cut some 90°s out to go over the bends I wanted to be in the smaller hose, as a reinforcement.
    • Just a heads up. Mine has just failed. When i turn the car on it just reboots everytime then the word "Android" shows up then goes to a black screen. I've aksed the company i got it from for some help but it's passed their 90 day return so they wont help. I have to swap back to my old system this weekend 😭
    • Does the car have to stay auto? If so, you might be looking at a ZF swap in future.
