The tyre is Bridgestone Potenza.
Does anyone have any long term experience with these?
Standard issue from Nissan for most of their vehicles in their range. Generally, pretty average performance but still better than the shitty Kumho KU31 tyres my compliance workshop recommended. I'm definitely going either Michelin Pilot Sport or Pirelli P-Zero for the next set. I doubt I'll be able to find the right size for the front so I'll stick to the all 245 set up I have now.
Edited by The Max
  • Like 1
I think 245 all around is good really...Well then again I'm not a fan of running a staggard setup...Compliance put on Dunlop Sports Maxx for me...Am quite surprised how good they are..I expected them to be shit...Done 37,000 kms now and they can probably go another 10k? My tyres normally run out way before this haha. Next set would probably be Yoko Advan Sport, P-Zero or Nitto...
  • Like 1
  • 7 months later...
I've never heard of Nitto.
But was wondering how wide can I go with 17's before I'd have to change to 18's?
Has anyone had problems (tyre scuffing side wheel guards) when running 18's on Track Days???
Because when I changed 17's to 18's on my HSV Clubsport-VR, they scuffed my guards?
Had to bend out the guards to stop it, lol...
Also would anyone know these details below;
17" Rim Width? ie. 8"
PCD/Fitment Pattern? 5 x 120
Offset? ie. +42
Many thanks for the help guys...
Edited by PaulReeves.com - GPOWER.TV
Don't know why I could re-edit my post???
But of course it's a 350GT (Does no one read the profile stats on the left of the user? Lol)
I was wondering how wide can I go with 17's before I'd have to change to 18's?
Offset? ie. +42
Offset? ie. +42
Why would you want wide 17's on a V35 Sedan?
I would be looking for 8.5" or 8.75" x 18" wheels - good value and affordable + look good... I don't think you'll encounter any guard rubbing issues with these.
PS: For tires, if you're looking for bang for buck (affordable) I'd look at Achilles ATR Sport / Sport 2
it isn't about rim diameter.. you could easily enough go with a wider 17in rim to fit wider 17in tyres if you really needed to, there is no 'requirement' to change to an 18in rim.
I'm not sure what width you could go up to on a V35 before you rub on the guard.. it would also depend on rim offset, you would need to select an offset so you don't rub the guards or the suspension.
  • Like 1
What I meant was... 17's are small on a V35 sedan! :P
Hadouken..I was referring to the specs of the above rims, if they would fit my PV35 Sedan or not...
But I done a Google search just now & found an excellent web site (www.Wheel-Size.com/)
http://www.wheel-size.com/size/nissan/skyline/2006/#trim-pv35-jdm
It shows year by year & model info what can fit....
Bolt Pattern on all V35's is 114.3mm!
Tyres for Nissan Skyline 2006;
Diameters: 16'' - 19''
Width (mm): 205 - 235
Tyre aspect ratio (%): 40 - 65
Smallest tyre size: 205/65 R16
Largest tyre size: 225/40 R19
Rims for Nissan Skyline 2006;
Bolt pattern 5x114.3
Diameter: 16'' - 19'';
Width (inches): 6.5 - 8;
Offset (mm): 30 - 45.
Does anyone run 19's on their PV35???
Comments please???
Or shall I stick to 18's for the track?
If so, what width of the rim & offset shall I get not to touch the guards or shall I ask Taleb Tyres @ Tempe regarding this query???
Ta.
Those figures are wrong. you can certainly go with a wider tyre than that. I have 245 tyres all round on my sedan, and that is with Coupe 18s. which have a lower offset than the normal sedan rims.. I expect you could go at least a few steps wider if you have a rim with a higher offset than +30.
245s on 18x8 +30 rims come very very close to the guards on the sedan!
You can also go with a larger rim than 19in, if you select the correct tyre. personally I wouldn't due to how much road imperfections will be transmitted through to the body of the car.. but that is up to the individual.
You also CANNOT use 16in rims on a series 2 or series 3 V35. these series have larger standard brake rotors and nothing below a 17in rim will fit over the front calipers.
Edited by sonicii
  • Like 1
(1) So how does the offset work?
The more lower the number the better to clear the guards? Or is higher the number of offset the better?
(2) Can I run wider rear than fronts like the GT-R does then? :)
Just google it FFS. This isnt a childrens learning centre.
(You can run staggered wheel sizes if you want. But knowing your understanding of wheels it will probably end badly. Do some research, see what other people are running)
  • Like 1
plenty of good explainations of offset on google, with pictures which will make it easy to understand. lower number means wheel will be closer to the guard.
Factory coupe tyre sizes with 18s run 245 rears and 225 fronts, 350z does something similar. my sedan came with coupe 18s with this setup.. I changed to 245 all round so i can rotate tyres. It also gives me just a little more clearance at the front with 350z springs.
  • Like 1
Dont listen to these Guys, just get really, really, Fat tyres, Fat tyres are fully sick.
And sick wheels, chrome looks really, really good,
Dont worry about that offset stuff, you can fix it with a block of wood.
Do your 245/35/19s rub at guards 'INSANITI'?
Would I be able to run 19's at the rear & 18's at the front then?
Whatever this setup would be called?
Or should I stick with 18's all-round if I want to run Pirelli P Zero Semi-Slicks?
  • Like 1
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
