hey guys im helping a friend out with converting there r31 skyline hotplates to leds and was wondering how I would get the lights to come on at a dimmed brightness as taillights and full brightness as brake lights. ive done heaps of research on it as I was going to do this when I had my r31 but am unsure how the led rings would work as taillights when there are only 2 wires off the led?
is this already setup in the taillight harness and all il have to do is wire the lights into the existing harness?
will I just be able to wire the leds into a plug and plug them into the existing taillight harness? and if I do this will they still work?
I have the hotplates and the led rings im going to use already but cant figure out how to make them work as taillights, I spoke to my local auto elec but he didn't understand what I was trying to explain so I hope you guys can.
also will I be able to wire both individual led rings into one plug to plug into the existing harness in boot of car?
as you can tell I know how to do most of the work but I cant figure out the electrical side with wiring, also can I just use the existing plug on the hotplates and will I need a relay of any sort?
hope you can help me figure this out as if it all works out I wanna start doing it as a at home business due to the fact there is no off the shelf aftermarket led taillights.
cheers in advance guys
I am 99% sure you can't do what you want with those lights.
It is very uncommon for LEDs to be able to be dimmed, some expensive 240v ones allow for this by adding a resister but cheapies will either be on or off, not dimmable.
the lights are 39 smd, chip type 1210, voltage dc12v
if I cant doit the way I was hoping would it be possible to wire the outter ring as the taillight and inner ring as the brake light? there 2 separate leds with separate wiring so this should be possible am I correct?
am I going to be able to wire the leds into the existing taillight loom in the boot by using the original plug on the taillights?
were can I buy a micro controller and pwm and how exactly do they work? all were trying to do is convert the standard taillight to leds by changing the internals.
By specs I mean do you have a link to the unit, it will be easier to help then.
Sorry I read your first post as only having one ring that you wanted to use for both park and brake. If you have two rings it will be easy as, you will probably need a resistor for the park lights. Need more info on the lights to figure it out though.
Yep should be able to do that, provided everything else is sorted first.
Disregard what I said about micro controllers and pwm if you have two rings per light
oh sorry, I cant find the link atm but il have a proper look tonight and post the link up. so would it be easier to just have the outter ring light up as the taillight and then the inner ring only come on as the brake light?
and the original post I wanted both ring to light up as taillights and get brighter when I brake but if that's not possible il have to go a different path so il use the outter light as the taillight and the inner light as the brake light. will I be able to wire both outter and inner lights into the old plug or will the brake light need to be wired seperatly so it only comes on when I apply the brake?
Edited by scithe93
ive drawn up what the design I wanted is and what the design im gunna settle for is on paint on my laptop but cant figure out how to upload them to this post. if someone knows how I can put the pictures up to give you a rough idea of what I was trying to do
It's entirely possible haha sorry a bit off my game today.
To upload images, host it using something like photobucket then copy the img tags into your post.
If I've got it right here's an easy way to use the same light as stop/tail. (the single led represents all of yours)
Just need the specs on the lights to figure out R1 and R2
You'll need to think up a voltage divider circuit for the park lights.
Or... Two circuits connecting the LEDs (depending on how you want the lights arranged), one circuit connecting to park and the other to the brake wiring. Not sure what voltages are outputted (you can easily measure those), but a crude way of wiring them up... pretty much what r31slpr posted.
After some diodes and resistors, the lights should get e.g. 5V for park and 12V for brake.
sweet as cheers guys when it comes to electricals im not einstien lol only doing it to help a mate out coz I know how to pull the 31 lights apart and reseal then perfectly. I put a foot up his arse when im over there on the weekend and get the specs and were he bought the leds from anf get back to ya's
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
