ok guys so i know there is quite a few threads about this but there are also a lot of different answers, so I'm looking for something more accurate.
so i have a 1996 r33 gtst series 2 and a week ago it was fine. one day i got in it and drive it and every time i hit the throttle it has a horrible miss. SOMETIMES if i take it out the road for a drive it may be fine then later ill get back in it and its the same again.
i pulled the coil packs off and the fourth plug had water in it so i blew that out n put it back together with excitement thinking id have fixed it but it didn't. i didn't actually pull the plug out, just dried out the water around it.
please help me, this is doing my head in! :/
Cheers, Ethan!
Edited by Baldwin1993
https://www.sau.com.au/forums/topic/446002-horrible-miss-r33-gtst/
not all places stock Bcpr6es or Bcpr7es. usually supercheap and repco wont but call them up and ask and otherwise they should be able to refer you to a place that will.
Beyond that, how do you have water getting into your coil valley area? this is not a good thing and worth sorting before you put in the new plugs...
Clean the coil valley out, clean the coil packs and replace the spark plugs. There's a youtube post for fix misfire on r33 gtr where you basically add some dielectric grease (headlight bulb grease supercrap has it for a dollar a pack) to the bottom of the coil pack where the spark plug pushes up into the boot. Worked great for me on several cars.
