My car had an 040 installed and had ran fine for about 3 months.... then i removed it one afternoon to have a fiddle, and upon re-installation i got the mounting height a little off.
The fact that i was in a hurry to get the car back together and running, i didnt care too much that it sounded like it was sucking a bit of air. So i just made a point of keeping the fuel level pretty high (something i didnt really always do the 3-4 weeks during driving recently around Melb) :Oops:
So my question is, i think fuel pumps use the fuel to cool the bearings, so would the pump sucking air, and cavitating help cause the pump to fail.... my car appears to be doing a lot of cranking and not much firing.... :)
How tolerant are fuel pumps?
https://www.sau.com.au/forums/topic/44606-bosch-fuel-pumps-failing/
I had one apart a couple of months ago. The actual stainless rollers that fit in the ceramic housing kept jamming, either that or it was the brushes. I'll get it so you can have a look sometime as it is just across the road.
Roy -
I installed a 040 in mine almost 18 months ago, and mine made that sucking air noise. I ended up re-directing the fuel return line, as it seemed with the bigger pump, it was casuing cavitation around the pump pick-up, as the fuel return line squirts right next to the pump.
I used a small piece of fuel line, and a aditional hose clamp and directed it away from the fuel pump pick-up. Problem fixed, and it stopped sucking air :)
I have also spoken to a few workshops about this, and they recommend doing similar. Mine was installed prior to a track day, and performed without any problems, and had done about 50,000km since
I'd say if the pump has sucked alot of air, it may have over heated and damaged a bush/bearing?? Might be worth a shot re-directing the return line like I did, it worked for me
Chris
Chris 32, i did that when i first installed it... it ran spot on.... and it was still there when i re-installed it in a hurry.
So the only way that may have been the problem was in my hurry to get the car back together and drive from Syd to Melb, i mounted the pump higher then previously, or i mistakingly placed the return outlet inside the baffled section of the fuel cell.... Its easy enought to check if the fuel pump has failed, just more fart a55ing about
yeah, maybe it has just plain old worn out?? All the hoses where tight?
Are you running the standard fuel pressure reg.? Maybe check the fuel pressure with a accurate gauge and see if its starting to fail
I have seen a car transformed when the pump was replaced. The faulty one was running but at idle the return fuel was almost non existent, and with a few revs just disappeared. GTR pump installed and plenty power now (but not mine which is choking on fuel unless I run almost full advance. The Bosch one he had just siezed.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
