Hey I've been having random starting issues and after it finally showed a diagnosis code I removed the cas - and I found the the exhaust cam bolts have rubbed against the cas! Am I missing a gasket or something to give it more room?
I would have hoped the mechanic would have noticed when they were adjusted!
https://www.sau.com.au/forums/topic/446065-adjustable-cam-destroyed-cas-wtf/
Well when I got it back from the tuner it had new bolts on the cas - so I'm thinking they replaced the original and didn't put washers back on!
I think I will be having words with them....
  • Like 1
Wow.
And looking at it it appears to be set to zero. Bit hard to see in the photo though.
I think it has a small adjustment.
I've put it all together and it still won't start - the injectors ticked when the cas was spun, and there's spark in the plugs - so fuel problem?? Or would the replacement cas put the timing too far out to start it????
Piggaz is on the money. No washers inside that rubber gasket causes the cas to get too close to the cam gear. It doesn't look like there is any of the washers inside that gasket in the pics.
Edited by Chris32R
R32-25t - I think that mark is where a washer used to be as the gasket is pretty hammered!
double check that the input shaft for the cas hasn't snapped off
Yeah the input shaft locator is broken off in the cas - so I'm trying to line up the new cas into the shaft, but it's bloody hard!
AF53B8B7-3F5C-424D-9AB8-F0DFBBF75FC8.png that's a washer, you can see the outline of it clearly
Ah I can see what you mean now I'm at the car - there is a small washer inbuilt into the gasket on the cam cover - if this is all that's needed I'm confused how the cas was touching the cam bolts....
can happen if the wrong washers are in there (not thick enough) but hard to say just from the pic. They look right, but you might be best off doing some measurements I think. Measure the thickness of the washers, etc. If you can source another CAS (cheap second hand one might be best) and put it in the car then turn it over by hand slowly and listen to see if it rubs it might tell you a bit more. I'd order a new seal and washers, not that expensive.Then see if it still hits
I've now replaced the cas - as it was scored on the inside.
I have got the car briefly running with it all together - and I think it is clearing fine as no marks are on the new cas so the gasket with washes included must be fine.
On reflection, ages ago I had the car running without the cam cover for a short drive, and didn't hear / see it rubbing, but I guess it must have been - a lot of damage with only 10mins of running!
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
    • Not required but appreciated. Super Coppermix Twin even the non-competition model feels like the pedal is noticeably heavier than stock which was pretty well judged IMO. I'll be swapping in the Nismo operating cylinder soon to see how that feels.  Personally I haven't felt anything that justifies replacing the damping loop, at least compared to more modern stuff where the clutch delay valve is actually quite noticeable.
    • He made that comment in my thread - In my case the vents ARE to lower engine heat, when the car is not moving, which is the only scenario I have heat problems with the aircon on, sitting in traffic, on 40C+ days. I can't imagine a scenario that this NC needs any at this point in time. I do not know if it will actually make my cooling when the car is MOVING worse, and I sincerely hope that won't be the case. If it does, well, um, f**k.
    • Nice, thanks. Thats why I was asking, there'd been a fair bit of discussion in the E90 world about vents and where it makes sense to put one (ie, over the filters is not great as that is inline or slightly behind the struts and in higher pressure area). I struggle with air flow and pressures. It sill weirds me out that a radiator in the boot can work.
    • Neither really Vents, when located in the right place, will lower the engine bay "pressure", as air has a path to escape, thus lowering the engine bay pressure, thus.....improving the efficiency on the coolant stack (read: IC, condenser, radiator) This is why the Blits vented bonnet on my 33 worked so well, the vent was in the front 1/3 of the bonnet, which put it right after the radiator  If the vents are to far back toward the windscreen, which is a high pressure zone, it can actually force air into the engine bay, causing higher pressure and effectively loosing efficiency on the cooling stack, like the fab of raising the rear of the bonnet, which does allow heat to escape, but only when the car isn't moving  There's heaps of cool "fluid dynamics" info out there, but, I'll attach a video of a 'Merican joint that focuses on "Miatas" as I found it when looking into vents for mine, they explain it way better than me
