Power Loss On Downshifts, Bouncing Idle And Slight Hesitation At Specific Rev Point -R34Gtt
haha thanks man, will keep you in mind if I dont find one in Sydney.
Does anyone in Sydney have a NEO CAS that I could borrow for the weekend??
You can keep mine meanwhile, its fully functional just need to see if its the culprit of my problem. I have the timing gun and my base timings set to 15deg
R33 Series 2 1997~1998 fits
R34 GT-R fits
hey you got a series 2 R33 ay Johnny? Do u remember I met you once in the city @ Darling Harbour, you gave me a fuel damper part something... ;)
yeah I do (again) lol...
vaguely, was a fuel check valve?
If I still had that S2 I could have let you borrow the CAS as it used the R34 NEO CAS - however my current shit box uses the metal CAS so can't really help :(
yeh fuel check valve something lol, thanks no worries mate, lets see if theres anybody else on here with a NEO CAS in Sydney
Edited by rondofj
Also I'm confused about the coolant temp sensor - I know the one going to the ECU is the one to test/change not the one going to gauge, and then u have a third element, the thermostat which some people reckon is good to change??
yes 3x elements..
1x sensor (single wire) goes to your dash to show a useless needle
1x sensor (dual wire) resistance base, goes to your ECU to report back coolant temperature, this is also used to determine the enrichment values when the motor is cold.
thermostat aids the car to get to the right operating temperature fast, R34 GT-t like to operate around 90 degrees, R33 GTS-t like to operate around 80 degrees - I once bought a R34 GT-t thermostat and installed it into my car.. worst move ever LOL.. now I run the correct one.
The faster the car warms up, the less fuel it will used (based on coolant enrichment).
In your PowerFC menu.. there's a table that shows you water temp vs. injection correction - this defines how much additional fuel is required in vacuum and 100kPa+.. column one will have a lower valve than column 2 naturally.
Temps read as expected- I think it was 15C at startup-not sure will check again, but it goes up gradually with warming up/ driving, 32C, 50,65, 78,- was 78C for the rest of the drive last nite including power pulls before shutdown. This powerfc reading is taken from the coolant temp to gauge right? Or the one to ECU.
Sweet man, that confirms that the coolant temp to ecu is working well, as its talking to the ecu which is displaying the different temps with time, tonites drive start up was 23C and crept up to 73C after which I didnt check. Leaves the O2 sensor to test, TPS maybe and of course borrow NEO CAS :S
One other thing I get these 2 values 23 degrees under Ign Cor change from 24 to 23 to 15 degrees everytime u go in to check- is this normal? See pic
That's the current ignition value being read off the map and the adjustment is a master trim - however temporary.
That means you can add or subtract a blanket timing value on top.
I just drove with O2 feedback disabled in power fc and the O2 sensor plug disconnected ( this didnt throw up engine check light?).
Strange thing the power fc sensor check still shows 0.2V for the O2S field with the sensor disconnected.
Drove the same, bogged down for 5secs on uphill downshift :(. My engine light mostly but not always flashes during approx 7000rpm+ in second. Peak values for knock remain low but airflow always shoots up to 4.9V+, is this normal for that gear n rpm? I think thats what flashes the light because even inj duty doesnt go past 75%
Edited by rondofj
Try and borrow a data logit kit from someone off the forum and do a log. That way you'll have in essence a data cube from which you can see what's happening.
I sold my kit a while ago when I sold my old car however if you can borrow one I'm more than happy to help you diagnose your problems for a few beers lol
  • Like 1
yeh it goes 4.9V+ all the time, isnt that normal at high boost/rpm?
How was it scaled? using the default Z32 AFM scaling or custom?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
