Power Loss On Downshifts, Bouncing Idle And Slight Hesitation At Specific Rev Point -R34Gtt
Update so far- just replaced my O2 sensor with the NTK R33 sensor- cut off plug n crimp wires- works.
Pics- left one is stock R34 sensor when I bought car 4yrs ago and after a year of use.
Right one is the O2 sensor I replaced yesterday- as u can see running pig rich, also confirmed by spark plug pics earlier.
Havent test driven yet but dont expect massive improvements.
Lookin for a stock GTT fuel reg- wrecker wanted 50 bucks told him see ya later ;)
All this to solve my loss of power, huge fuel use, bouncing idle( havent had bouncing idle in ages), inconsistent running sometimes, not much now though. Main issue is a fair bit of power/torque loss and fuel use- finding it not so easy to spin 2nd now as before- not that I want to.
The power loss at downshifts and also some upshifts is most possibly the bov entry angle and doesnt bother me for now till I get these other issues sorted.
Edited by rondofj
From todays driving I can confirm that now theres absolutely NO bouncing idle and jerky/hesitation/roughness in the 1500-2000rpms band and idles possibly a wee bit smoother- this with new O2 sensor n feedback ON as recommended by Yavuz. The O2 voltage is also in the 0-0.1V band under idle and alternating quickly when driving as it should, generally in the 0.1-0.2V band during low rpm driving- previous shagged O2 sensor would always be at 0.5-0.7V(rich).
But I still have a dramatic power loss as from the last 3 weeks- boosts to 22psi but no power/hard to spin in 2nd even whereas before you could just stab so lightly and spin at will. Before it also used to rev a fair bit quicker, now not. Boost leaks have been tested twice and I've killed myself fixing these. Nothing else changed, base timings 15deg as checked/set with light off no1 plug n also confirmed by power fc readout. Havent touched any timing/fuel maps so cant be these.
So I suspect its still running rich - water temp goes to 76-78C as usual, once went to 81C on a hotter day. So where the hells my power gone?
Bloody AFM again? Buying a wideband in a week or two to check afrs then I dunno next step. Need to have my power back and the fuel economy back (will be tested now Ive replaced the O2) before fixing the bov entry which is the least of my concerns right now.
Edited by rondofj
Your right, would my carbon-fouled plugs be a big part of my power loss or is that more like a secondary thing to look at later?
they didn't look too bad but as XKLABA says they are just a sign of the problem. would still love to see a youtube video of the perceived problem.
Overfuelling. Both plugs n O2 sensor were fouled. O2 replaced. Temp sensor to ECU works n displays correct temps but not ideal - usu 76-78C this winter. I dont blame tune cos before the recent power loss it was running really great sometimes (only 25% of the time) but not all the time, but still overfuelling - poor fuel economy n fuel smell.
So what else can it be- AFM is all my little brain can think of..
Edited by rondofj
when you get your wideband kit do some logging....if its as rich as you say it is then you'll see 10's on the afr gauge.....the fact your map trace on your commander jumps cells still leads me to believe the AFM is a bit bung....
Yeh I will do that. Could you explain the map trace a bit- theres the fuel n timing maps, both 20X20 cells. I assume the car can be at only one specific point at a time on both fuel/timing maps - eg row 3, column 10- means that it has to be row 3, column 10 on BOTH maps and this is what the map trace shows right? It shows that specific point (r3, c10).
My fuel map is shown in 'percent' values I think- the idle cells are generally 098,097,100 etc. I assume that this is a ratio of the stoich ratio 14.7:1 ie 098 is 14.7/0.98=15:1 AFR am I correct?
Edited by rondofj
If thats the case that means I can see from the map trace what afrs its running by noting the cells then going to the inj map to check the afr of the cell? Tedious but
Edited by rondofj
It's one way to look at it but you need to know what correction values equate to lambda values or stoich. This can be done but is usually what your tuner will do when seeing your base fuel map. On the power fc 100 equals 100% of the stock value. There is another page where you set your injector correction factor. Like I said earlier if you can be bothered sending me your recorded values I can take a look for you.... To see if there aren't any blaring issues.
you can download the universal power fc-edit software off the web. download that and plug your values into that, might be better.....then you can just save the tune file and send me that.....but change your AFM first.
See attached fuel n timing maps - seems like an unwanted 'wedge' in a part of the timing map (orange/ yellow)
Ron R34GTT Fuel Map.pdf
Ron R34GTT Timing Map.pdf
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
