Power Loss On Downshifts, Bouncing Idle And Slight Hesitation At Specific Rev Point -R34Gtt
Adjusted my cas to 20degs base timing with TPS connected- see how it drives tomorrow.
I can't believe you haven't specified in that sentence s what timing the power fc was displaying! (Actually I can believe it)
  • Like 1
Me too. But thats where the cas was before, and also when I did the belt early this year thats where I set it at 15 but had Nistune. Remember this is 20degs now with TPS connected as suggested by some of you this morning (since power fc). TPS disconnected reads 25ish.
Funny thing when I disconnected TPS then reconnected with engine running it went to 15 instead of 20. Then turn engine off, tighten nuts, then engine on and it went back to 20. Very sensitive to even slight taps of rotation.
Edited by rondofj
Isn't this why some tuners turn the CAS all the way advanced or retarded and then compensate for it in the ECU? So people can't just spin it willy-nilly and adjust the timing?
Seriously? Do you not get it yet?
What the power fc says it is putting out at idle is what the cas should be set at. You need to check that.
No way slightly tapping the cas or doing up the bolts moves it by 5 degrees. Unless you are totally ham fisted. It's the power fc putting out different timing. Not the cas moving. Unless ofcourse you are completely undoing all the cas bolts while adjusting them which is just bad practice .
This thread us unreal. Just the recap you aren't bothered with the one initial problem in the the thread only because you caused another more serious issue.....
Edited by Ben C34
Who knows. But the amount of guys doing random shit with the hand controllers is surely concerning to them. Now I know why tuners lock their tunes.
FFS Ronald a month later and 18 pages of nonsense! Give up and get the car to some kent who knows what he's doing! ;)
I know/understand you're a tight kent & can also understand that you are trying to learn/troubleshoot on your ride but the money you have lost in bad fuel economy probably could have paid to have had your car sorted by now!
Edited by Mick_o
thats what i'd call lazy tuning.... 'edit' took the wrong quote....meant to respond to this one. Isn't this why some tuners turn the CAS all the way advanced or retarded and then compensate for it in the ECU? So people can't just spin it willy-nilly and adjust the timing?
Edited by Badgaz
You seriously sound like your on your monthly periods sometimes..while other times you can be helpful,...I have seen your posts on other threads..and seen others give you a bit of a rub-down...
Lol....and life goes on. Let me play with my car and you play with yours right? If you can help then you can be sure its appreciated, if you start having your periods then I might just ignore ;-
I think he is trying to be helpful by stopping you from blowing up your engine.
  • Like 1
Mick I dont really care about the bad economy as long as I'm learning stuff and am able to fix it myself sometime, that is highly satisfactory to me. Even if it goes backwards n costs more in the long run. Part of the fun is learning, DIYs, fixing, enjoying, for me that is. Does that still make me a tight kent??
Calm down champ. Read back over what I have written, if you have the time.
This thread is really interesting and gets funnier as it goes on. Any moment now you are likely to pop your engine..
You say you want to learn about your car and buy tools etc, but won't buy a wideband and datalog it which is mandatory if you want to actually achieve anything rather than just taking wild guesses.
Remember the part where I said if your afm is dodgy your car is tuned for it? Do you get what I mean by that? If you did actually try someone else's afm you could very well kill your engine if not monitoring afr's.
Anyway man, keep this thread alive. Its interesting to See how long untill you either fix the actual issue or kill the engine.
Well I hope persistence pays off for ya son before you pull the pin and throw the grenade on that 25 :)
This is exactly why I do not have a hand controller for my PFC
  • Like 1
Im glad I do have the controller- learnt a lot of stuff- if it blows then it blows, its not a Porsche, another 3-5k will have an RB25/30 sitting under the hood with a whole lot of lifetime knowledge n experience : win
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
