Power Loss On Downshifts, Bouncing Idle And Slight Hesitation At Specific Rev Point -R34Gtt
Gareth, you have put 300k KMs on your 25, what are you doing laps of Australia or do you live in your car cause dam !!!!
I've owned my car since 2002. when i bought it it had 134,000kms on it. i've still never lifted the head off the motor and i've done all the maintainence myself....most of the problems are with the ancillary parts of the motor failing over time e.g turbo....
If you keep standard internals its well within the realm of possibility.
So you are saying it is possible with a blown 25 to build a 25/30 on the road for that price? Don't think so. Not even close.
My bet is that your highly strung 4G63 will grenade long before my 25 will! Crankwalk anyone? :woot:.. Mick O
Edited by rondofj
Lol care to place money on that Ronaldo? Dunno how its more highly strung? Im running a pound or 2 more boost than your car on Ethanol with a lower comp ratio and probably make similar to a little more power than you.
Its just a better designed more efficient engine than the old RB :)
agreed, RBs are old dinosaur tech
Where did they over engineer it?
Certainly not the oiling system....or the cooling system....or the cylinder head....or the turbo chargers......did I mention the oiling?
Stock engines weren't designed to rev at 8500 rpm for 10 secs bouncing off the limiter at double the intended boost. Do that to most engines and you will kill them.
Edited by XGTRX
Micko Atleast knows where his timing is sitting... Just saying.
  • Like 2
Yes, and I know this because I have done it. Thanks champ.
Same here. Stock bottom end untouched. All up less than 700 including oil etc for everything including retune. Took a whole week working on it a bit after work.
Not what I would call built though, as it's untouched.
But.... I know what I'm doing.... can set timing etc :)
Can't really see the point building one when a 200 buck engine does aso well!
Edited by Ben C34
  • Like 1
Sorry my bad. I assumed that going a 3L you would upgrade the supporting mods, water and oil pump, timing belt, clutch and at least a dyno tune. Obviously not the case, I apologise.
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
    • If you do make them, im sure you would have a number of buyers.. Every GTR I've been in have rattly door windows
