Power Loss On Downshifts, Bouncing Idle And Slight Hesitation At Specific Rev Point -R34Gtt
Just having it for fault diagnosis it's worth it, even if you don't do any tuning. If there was one aftermarket gauge to have on the dash, on a tuned car, this is it.
True enough for anything over 100kmh with a power run. The 97% of the driving you use a street car for however can be done with a wideband and some tinkering. The power runs is what the dyno is for but that is really only a small fraction of the time (money!) it takes for a tuner to tune the car, but I agree - it's no dyno replacement.
In the 7 years I have been taking my car to Scott he has never " road tuned " either of my cars and both my cars run fine sub 100kmph, the 32 has got over 600km from a tank full :)
I would prefer using the dyno as it is a controlled environment
A wide band is good to have but how accurate do you think a $300 kit is given the lab grade ones dynos use are $1000+ just for the sensor and then have the ability to tune yourself while driving
Agreed, and if you get something like XGTRX has posted if it can light up the shift light as a lean warning and pissible drop boost it would be a good thing
Any sensor is only good if it is tested and compared while in use. A $1000 lab sensor can easily get carbon impregnated and fail (usually from running cars too rich) just as easily as a $100 Bosch sensor.
The best option I believe is to compare the dyno gauge to the in-car Wo2, that way you will know something is wrong when there is a discrepancy. Of course you will need a third to check which one is faulty...
I have been to many dyno's over the last few years, and fixed a few also, most of the tuners down here are using Bosch sensors as they are cheaper to replace when they fail.
  • Like 1
True all O2 sensors should be tested and calibrated accordingly against a known working one or two, but do you think people are buying these O2 kits and then running them up on a dyno to at least check how accurate they are like they really should before they start tuning off them
Using elcheapo O2 sensors on a dyno as a sniffer is bad form on the tuners part and just to save a few dollars, a trade is only as good as his tools
My crappy Innovate LC1 worked perfectly for over 4 years, including track work. The same sensors are lasting perfectly well in OEM situations for many years. If the car manufacturers are fine with them, so am I. ;)
  • Like 1
I found that my idle screw was set in too far- would choke the engine when you remove IACV plug. So I disconnected TPS, IACV plugs and adjusted the screw out to idle (warm) at 800rpms as set on Powerfc without any electronic/ecu aid. After adjusting screw n re-connecting plugs back, checked base timing-was still at 20degs but feels right to drive, like it was before. No knock levels over 60, yes I do know the knock sensors arent reliable. And I bumped my TPS to show 0.45V at idle from 0.41V just to keep it at 'stock range'.
Heres my funny map traces
post-49401-14100717506173_thumb.jpgpost-49401-14100717655576_thumb.jpgpost-49401-14100717820722_thumb.jpg
The first two pics are a normal 30sec low rpm below 2500 drive in 1st n 2nd then a power pull in third revving out to 6.7-7k rpms.
Third pic is a pull in 1st, 2nd and 3rd
Edited by rondofj
I've read most of the content in this thread. Interestingly I am having somewhat similar issues with my car. It will get a little sloppy between gears until boost ramps up. Idle can also be retarded when the car is warm. My car is an R33, some similar parts but the one that has hit me the most so far is the f**king Gates timing belt.
I use one. Its a piece of shit. When I first installed it, it was noisy. I had to pull everything apart and tweak it. It still makes noise. I took it to a shop and they said this is why you do not use a gates belt. f**king piece of horse shit, I should have just went with the Nissan.
None the less my car is going to Unigroup this Thursday to rectify a misfire. I also need to eliminate the slop I've created in my tune by pulling timing to eliminate a ping.
Does anyone know if Unigroup are able to provide ECU's? If so I might get them to rip that f**king power fc and AFM out and give me the MAP goodness.
I love the PFC hating, I have one in my 32 and had one in my 34 and loved both of them and if they could do flex fuel it will still be in my 34, I sure I have said this before but will say it again, while near every tuner CAN TUNE a PFC very few know enough to do it properly :(
The first person that tuned my 32 didn't know and I hated it and wanted to swap it for anything else until I found Scott and after talking to him for 5 mins I let him tune it and never looked back, farkin excellent ECU, and in the 8 years it has been in my 32 it has never missed a beat
I have no issues with how the pfc works by all means both my cars run a poser fc. The issue for me was getting my tune to work with my new intake pipe correctly. I also wish they added the ability to give inputs. I would have loved to run flexfuel. The thing about newer ecus is they have higher resolution ignition and injection tables which can allow for a much more precise setup which can be felt on road while at cruise. Ive read only good things about unigroup and their ability to do the power fc but if i am able to get a new ecu to run a VE tune and leave the gates open for flexfuel then i would be a happy man.
Ron, have you actually matched the timing being displayed on the power fc in monitor mode to the timing you are setting yet? Like you are meant to. Or is 20 degrees just a random setting?
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
