Power Loss On Downshifts, Bouncing Idle And Slight Hesitation At Specific Rev Point -R34Gtt
  • 6 months later...
Thread wake up from the dead...
I finally found this elusive motherf**ing problem plaguing my ride for more than a year after the PowerFC tune. To recap - R34GTT running Precision 5558 0.63a/r 290rwkw @ 22psi on 98.
Problem was a massive power loss around 60-70% for at least 4 to 5 seconds when downshifting especially going up hills and also on those low rpm drives below 50km/h- slowing down, turning and climb up a right angled incline in 2nd or 3rd. The power loss is felt after slowing and turning. Also felt in some upshifts but to a much lesser extent and generally when high rpms. The power loss was so bad that uphill felt like it just wouldn't make it if it lasted a few seconds longer.
The result of this thread was numerous tests including swapping AFM, CAS, new O2 sensor, new plugs, new oil, new air filter (general service), disconnecting/connecting MAP sensor, adjusting TPS to 0.46V, removing n cleaning IACV, disconnecting/connecting it, blocking stock plumb back BOV with plate, checking temp sensor and other voltages thru PFC controller etc, even posting up my tune file for members to check. Getting tuner to check a couple times as well. Nope even they found 'nothing wrong' with my car...really... As well as that many people suggested my BOV entry angle to turbo intake wasn't ideal and it was possibly causing reversion, change that they said. NO I said, not convinced because I know fully well under what conditions it was happening and a lot of times under no boost as well.
Read other generic stuff online about traction control, popped bonnet, disconnected TCS sensor plug near firewall and bingo - instant transformation! New car from go, absolutely NO power loss or hesitation under these conditions, tested many times to confirm, that was it! Bloody TCS sensing slip when there was non/negligible and partly closing TCS butterfly for a full 5 seconds. Yet under normal takeoff / boosting while running and shifting to 2nd or 3rd etc with lots of wheelspin it doesn't sense any slip or close butterfly as it should -( the power is there from seat feel). Thinking it aint been properly tuned around in PowerFC am I right? Or dodgy TCS. This didnt happen at all with my previous Nistune and same all else setup.
One problem with disconnecting plug is the check engine light code. So I connected that back on and removed the 15A TCS fuse instead. No check engine light now and no TCS messing up my car = win -win!
Ask why I dont simply switch off my TCS switch - when I bought the car, was told that TCS dont work, I have never seen the TCS/SLIP and HICAS lights to this day (maybe globes removed?). Even the switch doesnt lock to its new position when 'switching' it, it comes back to its original position like a spring. is this how its supposed to be? My TCS does seem to be working (from all the problems its caused me) albeit very incorrectly..
Edited by rondofj
  • Like 1
Forgot to add - with the TCS disconnected as is now, it seems like I have suddenly gained massive power and torque through the mid and high rpms especially noticeable in 2nd and 3rd, its pretty insane the amount of grunt that I was 'missing' because my TCS plate was possibly partly/slightly closed even under all driving conditions. Feels easily around 320rwkw now from seat of pants feel
I did think of that, but the ecu would have measured less air hence less fuel and with no butterfly = more air/less fuel, is it possible I will be getting lean-out /danger ? Even for 5 seconds. Even though the TCS wasnt causing this temporary power loss with Nistune it was still not stopping any wheelspin from takeoffs and spirited 2nd/3rd runs either - does this indicate a rooted TCS ecu or sensor? Didnt know about the lack of ABS with no TCS- no good this :/
Your TCS system does appear to have a problem. Might have existed when you were using Nistune but the symptoms might not have been the same. or it might have developed since going to PowerFC. Can't remember the detail of when it started from your OP and really don't care at the moment either. What is important is that you need not worry about mixture problems. The TCS butterfly is exactly that. A butterfly. The ECU does NOTHING during a TCS intervention that it wouldn't do if you had just closed the main throttle. The TCS system sees slip it wants to stop, so it modulates the TCS butterfly. The ECU doesn't really know anything about this except that the AFM signal is decreased and so it will match fueling to air flow. That's it.
It IS possible that the ECU participates in a TCS event by reducing timing or something. By "ECU" I mean the Nissan ECU. PowerFCs I would expect to not give a shit, seeingas they can't even be bothered to do anything with the Knock sensor other than put up a light. So either way, not your problem to worry about.
Important point for you. Do not confuse the different parts of the TCS system with what they do. The "sensors" for the TCS system are really only the wheel speed sensors. The TCS throttle has a motor on it that is driven by the TCS system to close the butterfly. There is also a "position sensor" on that butterfly that is feedback for the TCS computer. Let's it know what angle the butterfly is at. It is essential for operation and will raise a fault code if not present. Hence why I suggested removing the butterfly from the TCS TB rather than anything else.
Tcs switch is a button... Not a switch
After looking at the entire system due to installing aftermarket traction control.....
TCS is entirely its own thing... It should have happened with either ECU surely...
As GTSBoy says... Check your ABS actually works. It uses the same speed sensors the Traction control does.... Which has a fault.
Good point Brad, what I understand as you say it, the powerfc doesnt regard the TCS as anything so my mixtures shouldnt be affected regardless if the butterfly is there or not or if its open/close. So off the butterfly goes- two screws right? Wonder if I can do it from front with throttle body pipe fixed as I dont wana remove that, all that waiting/running round for new T/B gasket.
Kinkstaah, is the TCS button supposed to flip back to its original position right after pressing it? Mine does, like a spring, press button from left to right and it comes back to the left
What is the TCS sensor plug near firewall?
He means the TCS butterfly angle sensor that I was talking about a few posts back. It's "near" the firewall inasmuch as it is on the TCS throttlebody which is broadly towards the back of the engine bay!
Good that its sorted now, lots of useful lessons learnt about sensors and which one does what and when and how the system works together, even better tested and confirmed that 'most' of my vital sensors and the engines in great health, thanks in a large part to SAU members for all the great help, guys like GTSBoy, Ben C34 and some others
    • Don't "upload" the pictures. Just copy the picture direct from somewhere (I usually am pasting screenshots or something else that I have on the clipboard as an image, not as a file" and just paste it direct into the post editor. Just like you were pasting it into a Word doc or something. You can't damage something if you lift it where you are supposed to. If you look carefully at the correct jacking points, you will see that they are reinforced right there. And nowhere else. That is where the "foot" of the factory jack is supposed to sit. That's why you need rubber pads with slots. 10mm might not be deep enough. Note also that the slots are not required if the pinchweld has already been slammed flat. You could just lift it at the correct spot with a flat pad, because the damage is already done. No point in making worse though, if it is recoverable. IF. Yes, that's called a chassis rail. You can lift carefully on these, if you spread the load. A decent block of wood is good. But keep in mind what I said before. Any time you start doing this sort of thing, you are off the normal path and into "be bloody careful", because it is obviously not stable. Dumb. The refinforcement is already there. See above.
    • yeah looks like they've been lifted there previously but with solid not slitted rubber blocks. I'd just bend them back (combination of vice grips or hammer with some sort of drift, then hit the area with underbody protection paint. As for the siderails, I'd call those chassis rails and that is exactly what I meant about being careful with the balance point. You can probably lift off them at the point where the 2 pieces overlap, but you need to be careful with the forward balance of the car if you do when the engine is in....sills are a better choice. I guess you could weld some reinforcement in the sill area near the jacking points but it shouldn't be necessary if you use blocks with a slit. If you do want to reinforce it I'd use square section equal or taller than the seam and then just use flat rubber blocks for lifting
    • driver side sidemember and jacking point (looks the worst by far) driver side rear jack point passenger side sidemember and jack point passenger side rear jack point   Ignore my mug on the last photo. Turns out I was just too stupid to properly use the forum's attachment feature previously
    • Fk me, I guess next time I will try to use the onsite attachments feature. I find it hard to work with so far though because I can't move the images to where I want them to be. I will try to make a separate post with just images. As for lifting. The work I need to do for now involves the exhaust and engine mainly, so the arm covering the jacking points is not a problem. But I don't want to bend in the whole sill or underfloor by lifting the car at the original jack points. I found some rubber blocks, 125 by 125 with a 10mm wide and 10mm deep cutout, which I'm hoping will work for not hitting the jacking rail. The sidemember, as seen in the service manual, are the rectangular frame rails that come from the front of the car and go alongside the gearbox and downpipe. Those that get crushed inwards if you use them for a floorjack. They are already slightly bent in from being used to hoist by other people. I think cutting off the jacking points and welding or bolting on a reinforcement plate along the sill might not be a dumb idea. Or is it dumb?     A 2 post hoist is what I'm gonna work with, but not for any underbody work, just leaky engine and exhaust work so far. Depends on what else I find that might need immediate attention. For metalwork on the sills I think I'd just bring the car to a panel beater. What's your take on getting rid of the original jacking rails and putting reinforcement plates along the sills?
    • Yeah titanium always looks cool but I don't need that, just regular pipes would be fine. But I am really struggling to find any full hardpipe kit that is still for sale.
