Power Loss On Downshifts, Bouncing Idle And Slight Hesitation At Specific Rev Point -R34Gtt
Ok I just went out n reduced all the acceleration pump settings in first column by 1.5 ms and increased decay time by 1, didnt make any difference to the bogging down on downshifts under load, sudden throttle input felt sharper I think, or maybe its my mind creating an illusion..
Sorry cant do mate, it wont help anyway, you have to be in car to feel it, and well the map tracer cells jump more than 5-6 cells down when it (bogging down losing power)happens, literally leaps downwards
Edited by rondofj
If it's dropping that hard it could be a mixture of TPS and AFM issues.
You really need a data logit kit connected to it.
There are many variables you need to look at which you're unable to do via the PowerFC controller alone.
Best to bring it back to the tuner or like I recommended get your hands on a data logit kit and post up your logs
haha..thats even harder - to find a datalogit kit for temp use. Only option is take it back to tuner..and get the same excuse that they couldnt find anything wrong/ didnt do anything to car.. you really think TPS could be an issue? - it does show varying voltage with varying pedal pressing, and is always within its usual voltage range..0.4- 4V or something, so thinking its alrite;
As far as I know, the only sensors that affect AF ratios are: CAS, AFM, TPS, O2 sensor, Coolant Temp sensor to ECU, MAP sensor - and probably in that order of importance. Probably in my case with PowerFC as some have said the O2 (switched off) and MAP sensor has almost bugger all effect.
Edited by rondofj
More of this coming this weekend - a more thorough test with a good 25-30psi in - hoping to find some leaks. Stay tuned.. Sorry bloody images got oriented wrong..
Edited by rondofj
considering the jump in cells i'd say either tps or afm. CAS does not directly affect a/f ratios....its governs spark.
its cheap and easy enough to change tps...i'd start there.
another consideration is maf reversion.
Yep - stock BOV is already blocked with a coke can plate to rule that out.. :). Something else I must mention, the idle goes 200rpms higher with the headlights switched off and lower with it switched on - alternator maybe, the belts checked tight enough - not sure if this issue is even relevant but. And TPS voltage is actually 0.41V at idle - might need 0.45V judging by other threads.
All this hunting around for a solution- my problem could even be a bad ground. Something that has been on the back of my mind. Any common ground problem areas/ which areas should I look for?
Edited by rondofj
It can still get reversion with the BOV blocked, when you shut the throttle the air built up by the turbo has to go somewhere and with no where else to go it goes backwards through the turbo to the AFM
That could also be causing and increasing the hesitation between gears
  • Like 1
fuarkkkkkkkkk
how have you wired your Z32?
Did you earth 1x cable to the chassis and 1x earth into the ECU?
If so.. there's one of your problem :)
both earths into the ECU (regardless whatever the interwebs says)
had the same issue with a S15.. each time the headlights were on.. the TP Load would increase as if there was more air going into the motor and AFRs dropped 1/2 a point... turns out with some hardcore googling.. DVS JEZ (legend) suggested to earth both together and into the ECU..
guess what? that solved the issue.
(yes I do tuning for fun).
fuarkkkkkkkkk
Nope both wires joined together and onto ECU as per SAU tutorial. I was actually thinking of wiring one to chasis but decided no go. By bad ground I mean check the earths from ECU, battery and other problem spots, clean metal, sand-papered joints etc. Think I'm goin to perfect my TPS adjustment to 0.45V instead of 0.41V, idle is 200-300rpms higher with O2 feedback off. Do u also have to disconnect the O2 plug, mine isnt?
Disconnect your idle control valve disconnect your TPS disconnect your AAC then adjust the idle screw till its sitting flat bang at the idle prescribed by your PowerFC then plug everything back in
  • Like 1
Put up a new list of everything you have changed and checked. 6 pgs is a lot to read through.
Have you tried a recirc bov just for the hell of it? The symptoms you described. under load in a high gear, then changing to a lower one would make the power loss from over fuelling more pronounced.
If you blocked off the bovs after the tune then this advice is spot on. So make a list of what have you changed after the tune would be a good start. I can't believe a tuner would let a car out like this.
    • Thank you 🙏 I'm patient, which is good, considering the limited budget (for now) more so trying to understand where to begin the journey and you and the others have been good with that, appreciate everyone for their input 🫡
    • $5-10k isn't much for reliability if your looking at more power for a RB Me, with that much money currently on hand,  I would only look at things to suit future mods, as stated, a fuel pump and ecu would be my first point of call, as well as getting the injectors cleaned and tested, maybe even replace all the coolant hoses After a little time with the tuner, they should be able to tell you how your car is running in relation to things like your ignition, cooling, and other stuff that will be picked up when it has had a few runs up on the dyno and some logs to look at Basically, get everything sorted for reliability before you start leaning on a 30 year old engine Good luck with the one and only true Godzilla, enjoy Note: for your birthday presents, ask your family and friends for lottery tickets, a 32 GTR can cost "all of the money" to make reliable power
    • Strictly street. Just wanting a bit more power 🫡 Have baby seat in the back too 🤣
    • Yeah ok, it'll be expensive. But it is what it is.  How do you plan to use the car? Any track work?
    • I do have their “Nissanie Motorsports Co.” vin plates, but I am curious if anyone would have more info on them. Like how many cars they’ve imported and whatnot
