the_tonkau Posted October 4, 2002 Share Posted October 4, 2002 I AM HAVING TUNING PROBS WITH MY SERIES 1 GTST. I WOULD LIKE TO SWAP OUT SOME PARTS TO ISOLATE THIS VERY ANOYING ISSUE MY MECHANIC CAN'T WORK OUT($900 LATER). I NEED A S1 AFM, A SET OF COIL PACKS AND AN IGNITER TO TEST WITH FOR 10 MINS. I INVISAGE DRIVING TO YOURS, SWAPPING THE BITS GOING AROUND THE BLOCK AND THEN GIVING YOU HEART FELTS THANKS AND PROBABLY SOME DOLLARS/SLABS OR IF INTERESTED A WEEK OLD UAS COLD AIR INTAKE AND O2 RUSH RACE POD. BIT OF A LONG SHOT BUT I'M SURE SOME POOR BASTARD HAS BEEN IN THIS POSITION BEFORE. THANKS GUYS STEVE. 0411 403081 [email protected] Link to comment https://www.sau.com.au/forums/topic/4461-melb-memberneed-help-s1-r33-gtst-will-trade-beermoneyperformance-bits/ Share on other sites More sharing options...
meggala Posted October 4, 2002 Share Posted October 4, 2002 yeah if you post your problem we could give you an idea. but first thing to check is your plug gap if your runnig over 8 psi this should be sewt to .8 mm not the default 1.1 mm. if the idle is bad and inconsistent ie going from 1000 rpm to 2000 rpm then your afm could be the culprit. also the coil packs and the the ignition apmlifier if the car is running rough. the crank angel sensor could be the problem if yua re loosing power over a certain boost. factory timing should be @ 15o . nex t I would be looking for a mechanic how knows skylines cause this guy obviously doesn't . last one is to check the cooler piping is ok. meggala Link to comment https://www.sau.com.au/forums/topic/4461-melb-memberneed-help-s1-r33-gtst-will-trade-beermoneyperformance-bits/#findComment-70478 Share on other sites More sharing options...
skyline33 Posted October 5, 2002 Share Posted October 5, 2002 is the car stalling?? are you running a pod filter?? from my experiences the air flow meter alot of the time stuffs up. Link to comment https://www.sau.com.au/forums/topic/4461-melb-memberneed-help-s1-r33-gtst-will-trade-beermoneyperformance-bits/#findComment-70509 Share on other sites More sharing options...
skyline33 Posted October 5, 2002 Share Posted October 5, 2002 i can help you on monday if you want drop me a line on 0401677698 and we can try and organise something Link to comment https://www.sau.com.au/forums/topic/4461-melb-memberneed-help-s1-r33-gtst-will-trade-beermoneyperformance-bits/#findComment-70510 Share on other sites More sharing options...
the_tonkau Posted October 6, 2002 Author Share Posted October 6, 2002 All pipes/intercooler pressure checked , correct heat range (7)and gapped plugs, reset ecu, Manifolds checked and tightneed, turbo removed and checked. Dynoed and mixtures seem solid at 11%(S-AFC installed and waiting for tweaking). When its warm(weather wise) it will pull through the rev range smoooth and hard in all gears, when its cold(weather wise), starts missing as it pulls higher boost even in second(high boost means 10psi in my case, no where near factory cut off). AND, fuel pressure tested under load OK and boost gauge tested as well?????? I tell ya it annoying but at least I know whats NOT wrong with the buggar!!! Link to comment https://www.sau.com.au/forums/topic/4461-melb-memberneed-help-s1-r33-gtst-will-trade-beermoneyperformance-bits/#findComment-70980 Share on other sites More sharing options...
meggala Posted October 6, 2002 Share Posted October 6, 2002 last thing to look at apart form my other suggestions is the crankangle sensor meggala Link to comment https://www.sau.com.au/forums/topic/4461-melb-memberneed-help-s1-r33-gtst-will-trade-beermoneyperformance-bits/#findComment-70985 Share on other sites More sharing options...
the_tonkau Posted October 7, 2002 Author Share Posted October 7, 2002 Yeah, timing is critical but how would that make a difference depending on the intake temp? (still haven't checked it though and don't know if the mechanic did) Link to comment https://www.sau.com.au/forums/topic/4461-melb-memberneed-help-s1-r33-gtst-will-trade-beermoneyperformance-bits/#findComment-70992 Share on other sites More sharing options...
meggala Posted October 7, 2002 Share Posted October 7, 2002 I had a faulty crankangle sensor and it did some strange things my thoughs are afm or coil packs myself. cheers meggala Link to comment https://www.sau.com.au/forums/topic/4461-melb-memberneed-help-s1-r33-gtst-will-trade-beermoneyperformance-bits/#findComment-70998 Share on other sites More sharing options...
Nightman Posted January 12, 2004 Share Posted January 12, 2004 I Have the SAME Problem as this... Cold = Miss, Hot = Fine! I Tried a BOOST Controller and its WAY Worse (even at stock boost levels) !!! I thought it might be the Ignition module not being able to handle the extra boost from cooler air??? I currently have .75mm gap which makes it drivable... but, on a 20deg day it misses under 60% > 100% Throttle (around 4500 RPM+)... on a 25+ day it does not miss a beat... the_tonkau: if you manage to fix this PlEaSe! let me know what it was as I am in a simular position... no parts to swap... no mechanic who knows.... etc etc... Link to comment https://www.sau.com.au/forums/topic/4461-melb-memberneed-help-s1-r33-gtst-will-trade-beermoneyperformance-bits/#findComment-639433 Share on other sites More sharing options...
blind_elk Posted January 12, 2004 Share Posted January 12, 2004 Factory turbo? Or 'upgrade'? Link to comment https://www.sau.com.au/forums/topic/4461-melb-memberneed-help-s1-r33-gtst-will-trade-beermoneyperformance-bits/#findComment-639450 Share on other sites More sharing options...
Nightman Posted January 12, 2004 Share Posted January 12, 2004 factory turbo! Link to comment https://www.sau.com.au/forums/topic/4461-melb-memberneed-help-s1-r33-gtst-will-trade-beermoneyperformance-bits/#findComment-639462 Share on other sites More sharing options...
the_tonkau Posted January 12, 2004 Author Share Posted January 12, 2004 Could be a lot of things and maybe a combination of two issues but my fix was(after lots of piss farting around, a faulty ignition module that was breaking down at higher boost! Dr Drift at BMT Motorsport (www.bmtmotorsports.com.au) found the problem! Good luck Steve Link to comment https://www.sau.com.au/forums/topic/4461-melb-memberneed-help-s1-r33-gtst-will-trade-beermoneyperformance-bits/#findComment-639587 Share on other sites More sharing options...
Dr_Drift Posted January 13, 2004 Share Posted January 13, 2004 And do tell every one how your car's going now?? Link to comment https://www.sau.com.au/forums/topic/4461-melb-memberneed-help-s1-r33-gtst-will-trade-beermoneyperformance-bits/#findComment-642002 Share on other sites More sharing options...
the_tonkau Posted January 13, 2004 Author Share Posted January 13, 2004 Needless to say it is been shaming SS Commodores and the such, left right and centre since the super mega drifto tune! Hey Dr, when you putting the NoS bottle on the BMW?...haha hehe hoo hoo....Shit I'm funny. Easy. Link to comment https://www.sau.com.au/forums/topic/4461-melb-memberneed-help-s1-r33-gtst-will-trade-beermoneyperformance-bits/#findComment-642323 Share on other sites More sharing options...
Nightman Posted January 13, 2004 Share Posted January 13, 2004 is there any way apart from swapping to test the module? Link to comment https://www.sau.com.au/forums/topic/4461-melb-memberneed-help-s1-r33-gtst-will-trade-beermoneyperformance-bits/#findComment-642386 Share on other sites More sharing options...
the_tonkau Posted January 14, 2004 Author Share Posted January 14, 2004 No, unless you made one up out of a Sultana Bran packet, but I don't think that would be a great conducter of ..........."currents"........hahahaha !! hehe Once again...DR DRIFT @ www.bmtmotorsports.com.au" DO IT! Link to comment https://www.sau.com.au/forums/topic/4461-melb-memberneed-help-s1-r33-gtst-will-trade-beermoneyperformance-bits/#findComment-642411 Share on other sites More sharing options...
Dr_Drift Posted January 15, 2004 Share Posted January 15, 2004 Nightman, The funny 'the_tonkau' used our last igniter module, but I still have a spare AFM, CAS, coil packs, etc if you want to try and find the problem... The most common mis-fire problem I've seen is plugs, follwed by coil packs, follwed by CAS, followed by igniter module... Doc. Link to comment https://www.sau.com.au/forums/topic/4461-melb-memberneed-help-s1-r33-gtst-will-trade-beermoneyperformance-bits/#findComment-645432 Share on other sites More sharing options...
ABuSD Posted January 31, 2004 Share Posted January 31, 2004 How much are all those parts to replace, Doc? I may have to visit u next time with Lucky in his Slug of a Soarer I have the same problem, and only running 11psi, and getting my ass kicked @ the lights Definatly losing power Link to comment https://www.sau.com.au/forums/topic/4461-melb-memberneed-help-s1-r33-gtst-will-trade-beermoneyperformance-bits/#findComment-666927 Share on other sites More sharing options...
Dr_Drift Posted January 31, 2004 Share Posted January 31, 2004 Depends on what's second hand at the time, see ya soon.... Link to comment https://www.sau.com.au/forums/topic/4461-melb-memberneed-help-s1-r33-gtst-will-trade-beermoneyperformance-bits/#findComment-666984 Share on other sites More sharing options...
