1989 Nissan skyline R32 GTR Tarmac Rally Car For Sale
Genuine black R32 GTR , imported and complied around 2006 as a 4.5 level car. Never any accident damage or rust. Built into a Tarmac Rally car in 2010 at enormous cost. Very successful history including 2 x Targa Tasmania’s, 2 x Targa High Country’s and Targa Wrest Point. Car is on full QLD rego, with all mod plates for cage, seats, brakes etc.
We also have a 1984 Nissan DR30 Tarmac Rally Car, and can’t decide which one to sell, so we are putting them both up for sale and see which one goes first… DR30 can be viewed (link to be added)
Back to the R32 GTR. List of mods include (car is now de-stickered):
Genuine fresh N1 Crate engine, recently rebuilt by SJP Engines (2 events old) with forged pistons, ARP studs, Ross balancer etc. all quality parts. Shows 300+ RWKW on BP98 tune with legal Targa specs, tuned for strong midrange, full details to genuinely interested parties.
N1 turbos and custom stainless/titanium exhaust (with removable cat/decat section)
Direct Clutches button clutch setup (comes with brand new spare)
PWR Radiator, power steering cooler and oil coolers
R33 GTR intercooler
Nismo mounts
Bigger 650cc injectors , with lift pump to sealed boot mounted surge tank and 044 supply pump on custom wiring
Freshly rebuilt R33 GTR gearbox, including transfer case rebuild
Nismo Pro TT rear LSD and Quaife geared front LSD with 4.375:1 Diff gears
‘Full Race” Pro or Ruzic diff controllers (your choice, both currently in car)
All driveshafts, tailshafts etc serviced 2 event ago
MCA gold/Proflex remote canister shocks with fast and slow bump and rebound adjustment
Adjustable platform King springs, currently 550lb front and 450lb rear
Whiteline sway bars F&R
Nismo front handling kit including control arms & upper arms
Cusco rear adjustable camber arms
Apexi computer and remote hand controller and HKS boost controller
Brakes:
Option 1: Evo X option 350mm x 32mm front vented discs and Brembo 4 spot calipers and rear 300mm vented discs and 2 spot calipers, with DS2500 pads
Option 2: Full AP Racing endurance brake package including 355mm x 36mm AP front rotors and Harrop floating hats, and 320mm x 32 mm AP rear rotors and Harrop floating hats. AP Racing endurance 6 spot front calipers (25mm brake pads) and AP Racing endurance 4 spot rear calipers (16mm pads) with PMU pads including spare front rotors, hats and brake pad set. This is the ultimate GTR brake package (cost $14k+)!
Both options come with braided lines and hydraulic handbrake Running standard booster and ABS (balance bar setup available separately if desired).
Body:
Rust free and accident free original metallic black. N1 rear lip and front vents. There are quite a few stonechips (as can be expected from a tarmac race car) and some paint removal spots (from decal removal) but overall the body is in very good condition and presents very well.
Full CAMS and AMSAG TIG welded, log booked cage from Pro Race Fabrications. Sparco Race seats and 6 point harnesses, Momo steering wheel, fire extinguishers etc. Interior is very neat, still has most trim and front carpet (all standard trim available with car).
Gizmo shift light
Flush carbon lockable bonnet pins
Genesis dry cell battery in boot with kill switch and remote pull
R33 GTR wheels and A050 Advan race tyres
Full QLD rego till 02/15
That’s about all I can think of for now, although I am sure there is more. This is a fun and easy car to drive quickly, and would suit the novice through to the serious competitor. There is plenty of development left, but it is an easy top 10 car as is. Would suit Tarmac Rally, Time Attack or weekend Top Gear series car that you can drive to and from the track. Always serviced, pre-race prepped and tuned by GT Auto Garage. Would cost well over $100k+ to replicate! Extensive spares available with car.
Price with option 1 brake package - $27,500
Price with option 2 brake package - $32,500
Serious enquiries only please. Located Brisbane Northside
Initial contact by email: [email protected] or Phone 0433 73 44 55
Cheers
Paul
Not sure how to edit the original add, but here is the link to the DR30 mentioned..
http://www.skylinesaustralia.com/forums/topic/446323-dr30-skyline-rs-x-turbo-tarmac-rally-car/
Cheers
paul
As far as I know if you brought it to Victoria you will need a rwc if you want either regular plates or club plates (which it is eligible for now as it's an 89).
I certainly wouldn't want the task of trying to get a rwc for it, you would want to be fairly friendly with the mechanic I would say. :-)
  • 4 months later...
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
