Hi guys
A few details before we start
R32 Skyline Coupe
RB25DE S2 (Manual) - ~160,xxxkm
RB25 Pink Label AFM
RB25DE S2 Manual ECU
BP 98 octane fuel
Basically what's happening is my revs bog down at around the 2.5k - 3.5k mark at around 1/4 - 1/3 Throttle and it sounds like it's surging almost? I had a similar problem recently throughout the whole rev range unless I had the throttle wide open so I ordered a new TPS and after installing and adjusting it that issue was solved however I'm still getting this strange bog down
So far I've replaced the Spark plugs, checked the coil pack loom for any wear but it looks quite clean and in good condition. I've recently replaced and adjusted the TPS, I've cleaned the MAF a few times now, replaced all the fluids, filters, air filter etc etc
I have coming from Nissan a new O2 sensor and fuel filter as i though these might be playing a part in the matter, I've also gone over the engine grounds to make sure nothing is going wrong. Should i be looking at a set of coilpacks? they look old/stock so they might've had it, im pretty baffled to be honest :/
My thoughts are that either the coilpacks are dying, or that it's running too rich (stinks of fuel lol, no idea of the o2 sensor history) and simply can't burn it all until i open the throttle more, I'll try find another AFM and see if that helps at alll
If anyone has some ideas to what I could try, please let me know :) Thanks!
https://www.sau.com.au/forums/topic/446113-rb25de-s2-bogging-down/
start with a cheap bottle of injector cleaner, mine was having similar problems where it will surge sometimes unless the foot is flat and i tried so many things and a cheap $10 bottle of injector cleaner fixed it within 20mins of driving
how did it go?
Hey Mick
Filled the car up and put in a bottle of cleaner and went for a drive, definitely felt a little better about halfway through the tank, still a bit surge-y and splutter-y at times unfortunately but a little better, car feels nice when it's smooth! :woot:
My O2 sensor arrived which i put in last night but I'm yet to take it for a drive so we'll see how it goes :)
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
