Hi everyone :)
I've built a new Rb26 motor for my 34GTR, now the stocky one I yanked out is being eyed off by my younger bro who has a Gtt..
Before I help him with transplanting it in to his car, is it as simple as going / calling vic roads about the swap so they can put it on file or will I need an engineers cert? (Melbourne)
was told by a mate shouldn't be a problem and a cert wasn't needed along as the engine was an option in the range, but I just want to make sure :)
I called vic roads but the chic didn't know her ass from her elbow ;)
Cheers :action-smiley-069:
You may be able to get away with it due to "but it came in the 34!!111" which it sort of did.
But in reality, it never came in THAT exact model, a GTT. That said, you can put a Turbo engine in a NA, and the chassis and other bits are different. It's a grey area.
As GTSBoy said in the other thread, why would you even do it? the ONLY reason I can think of doing it is to keep dat stock turbo look with twins, which is kind of a big deal in Victoria, but in any scenario that you are explaining "its stock officer" you'd better be prepared to explain how the engine found its way into a GTT, may be very much pushing uphill.
The neo is as good and/or better engine anyway, (VCT!, Solid lifters! Higher comp ratio!) requires nothing to change, zero labour, and like, IS standard, so unless you want to go 500+kw and appear completely dead stock from the outside, which would be really 'fun' in a RWD GTT anyway..... don't do it :ninja:
    • Yep that's a superb price and ther is no way you will over capitalise on you investment.  As to the bracket, again just use the passenger side seat  bracket ( obviously reversed ) as a sample to reshape it and in this case, TIG it back together.
    • Thanks for that.... If only I could do something once and be happy with that, like some people do....
    • I had no transmission at all so I managed to find a big box manual gearbox from an R34 GTT for an insanely good price in EU. I converted it to push type which cost more than the transmission almost, with parts from Amayama! These engines are very strong and can put out decent power with a properly sized turbo. You can save on money from parts like pistons and rods, and invest those in the transmission and other parts. I suggest you join the RB20 Enthusiasts facebook group, plenty of info and almost daily posts there about 20DE/DET/Neo+T builds. (I hope I'm not breaking any forum rules by mentioning third party platforms, just trying to help the buddy out)
    • Yeah, having tried all of those methods including BBQ+recipro/hacksaw, I ended up buying a bush press kit under $150 that works well, like this: https://www.ebay.com.au/itm/355967727167?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=sfmmuhxgqhm&sssrc=2047675&ssuid=dJvnaZ11TB-&widget_ver=artemis&media=COPY It basically has a range of pushers and cups with threaded rods between to press out a range of large bushes. The problem with any sawing solution is minimising damage to the subframe side, although it probably needs a quick sand afterwards no matter what solution you try due to damage
    • Hi. Thanks for the answer. I do not have instagram 😄 I too considering turbo the RB20DE NEO 🙂 But i think i upgrade the gearbox first or at least buy new.
