Hi everyone :)
I've built a new Rb26 motor for my 34GTR, now the stocky one I yanked out is being eyed off by my younger bro who has a Gtt..
Before I help him with transplanting it in to his car, is it as simple as going / calling vic roads about the swap so they can put it on file or will I need an engineers cert? (Melbourne)
was told by a mate shouldn't be a problem and a cert wasn't needed along as the engine was an option in the range, but I just want to make sure :)
I called vic roads but the chic didn't know her ass from her elbow ;)
Cheers :action-smiley-069:
You may be able to get away with it due to "but it came in the 34!!111" which it sort of did.
But in reality, it never came in THAT exact model, a GTT. That said, you can put a Turbo engine in a NA, and the chassis and other bits are different. It's a grey area.
As GTSBoy said in the other thread, why would you even do it? the ONLY reason I can think of doing it is to keep dat stock turbo look with twins, which is kind of a big deal in Victoria, but in any scenario that you are explaining "its stock officer" you'd better be prepared to explain how the engine found its way into a GTT, may be very much pushing uphill.
The neo is as good and/or better engine anyway, (VCT!, Solid lifters! Higher comp ratio!) requires nothing to change, zero labour, and like, IS standard, so unless you want to go 500+kw and appear completely dead stock from the outside, which would be really 'fun' in a RWD GTT anyway..... don't do it :ninja:
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
