HKS GT Supercharger Pro Kit to suit Nissan 350Z or V35 Skyline. Part number: 12001-AN004
The main part of this kit is brand new in box, the rest is used but in excellent condition.
The brand new parts include: Supercharger, Engine mounting bracket, traction oil cooler, oil tank, oil, hoses, belts:
post-9499-0-77130500-1406528465_thumb.jpg post-9499-0-96322800-1406528519_thumb.jpg post-9499-0-24433500-1406528559_thumb.jpg
The used parts include: intake pipe, air filter, intercooler, piping:
post-9499-0-31712700-1406528595_thumb.jpg post-9499-0-44763300-1406528623_thumb.jpg post-9499-0-57135300-1406528674_thumb.jpg post-9499-0-81189800-1406528655_thumb.jpg
$4000 Neg.
https://www.sau.com.au/forums/topic/446132-fs-hks-gt-supercharger-pro-kit/
It made 230 KW at the wheels. That was on a 2006 V35 Coupe Auto with aftermarket exhaust and an UpRev tune. With the kit removed and re-tuned with the same exhaust and stock intake it made 160Kw at the wheels. So it seems to add around 70Kw.
  • 1 month later...
What else is required for this to be running on a stock v35
New injectors (545cc and up). I had 750cc which I would throw in.
Engine management + Tune. I used Uprev because it is the only decent one for the auto.
  • 3 weeks later...
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
