I replaced the rocker cover gaskets and spark plugs on my rb20det. It was working fine.
Put it back together and wouldn't start.
I pulled a coil and plug out and attempted to start it and found there was no spark.
What could cause this?
You need an earth on the ignitor I don't see one in the picture above
I do see the wire to the left near the grey plug tho
Then bolt it to the block in the factory position
Edited by Sinista32
  • Like 1
Solved or still an issue
Unfortunately it's still an issue. I ended up doing a test at all the coil loom outputs and I'm getting power. This makes me think the problem are the coil packs but it seems odd because they were working fine before.
