hey guys rebuilding a rb26dett. just wanna get some info on what you guys have done
mainly motor is getting setup for the street and some events as power cruise. im not going to be pushing the rev limit but im goin for big power as well as big boost.
any info would be great especially on the ( oil problems ) oil restrictors and head drain as such
Edited by townzy92
https://www.sau.com.au/forums/topic/446182-rb26dett-build/
Sky's the limit. If money is no issue then go for best of everything. If your budget is pretty tight then do what you can afford. Bare minimum is the machining work for oil return before you worry about anything else! Then in order of priority is forgies and rings, oversized sump, rods, turbos, valve springs, oversized valves, and on and on and on. Everyone will have a variation to this and there's no doubt things I've missed as well. I'm presuming you'll have all the engine machining done, all new bearings, balancing of the crank, etc.
But at the end of the day, if you're not doing it yourself then go by your engine builders instructions.
https://www.sau.com.au/forums/topic/446182-rb26dett-build/#findComment-7354614
