So i have installed the motors and everything the whole system works no errors motors turn fine, looks like it does everything correctly.
The only thing is from the 00 setting to the 16 setting i really struggle to notice any difference?
Looking back through the instructions I notice they say to remove the grub screw with the clicker assembly and in stall grub screw provided in the kit with the loctite stuff and the grease and all that but there weren't any in there so I'm using the grub screws that where already in there with the clicker assembly?
Just wondering if anybody else has installed this set up on their 32 and can tell me if there were extra grub screws for the motor of this particular model dosnt need them or if this adjustment set up is just that over rated?!
cheers guys any feedback is much appreciated!
Ben
If it were me i would set EDFC minimum, take the actuator off and check the shock is on minimum by hand, then re-install the actuator, set it to maximum then remove it again an check its on maximum by hand.
  • Like 1
