Hi skyliners, going through trying to figure out why my r32 gtr is stuck in 4wd. Low speed turning you can hear and feel the front wheels trying to turn and the tyres scrub under the force. I used to have a 4wd controller but this has been removed. Even tried to take out the 4wd fuse and it still feels like 4wd. I have never seen the torque meter move since owning the car for a few weeks.
I have done some research checked the rear reservoir and it's topped up.
Any helps or places to start checking would help a lot. I turned the car on and tried to look for the leds in the atessa computer but nothing showed up.
I'm not 100% sure on this but a quick google would tell you.
The factory front diff is open which would cause each wheel to spin opposite directions when spun by hand with the car in gear.
a 2 way wouldn't want to spin in gear, but in neutral both wheels would spin the same direction.
Have a go and report back
edit: Thinking I might be wrong now... someone weigh in please
Edited by Blackkers
Mm. Front diff definately a possibility or maybe transfer case problem? Could it be the transfer actuator? Easiest way to narrow it down even more would be take out the front shaft and see if that makes any diff?
I have also had similar symptoms with wrong TPS. But that's not what you have.
    • As strange as this sounds (as they are fixed back), my Bride Xero CS seats are the most comfortable seats I've used.  I vote go genuine.  The only downside I've found is on very long drives, you can't reposition your body while driving. So even though its comfy, being locked in the same position eventually becomes uncomfortable. I find myself stopping every 3 or so hours to stretch my legs on long drives.
    • You don't have to be bored driving a Camry. Not based on the way that a couple of f**king Ubereats/Didi/othersortofmethaddlednightshiftattheservicestationrecentimmmigrants were piloting them on the way to work this morning. f**k me dead!
    • FWIW, the Bride reps are really nice to sit in. The only complaint I have, other than the tear in my bolster, is that the velcro used to hold the backrest cushion in place, up under the headrest, is a little obvious and intrusive and could probably be done better. I don't know if that is a "feature" on the genuine ones also though. I haven't looked at a genuine one like the ones I have, only some of the older models. The other thing is, even though I bought the CF ones, I think the CF is really just decorative, over the top of the same FG as the normal seats. And so they really aren't light. Between the solidly built CF/FG seat, the steel frame in the recliner mechanism, and the solid-arse seat rail, they are probably heavier than even the stock seat. They are a serious lift to get in and out of the car.
    • Yes, and so the barest minimum power target is the one that makes the most sense. Massive power is fun, but you can only use it for 1.5s at a time, and only every now and then. Medium power levels allow you to enjoy the car far more often and for longer. 500 engine HP is just below 300 rwkW which is about the maximum that is sensible for any street car really. And for a 2.6L six, it will still leave you with a decent boost response and some sort of linearity of power delivery. As you get up towards 400rwkW the onset of power tends to be increasingly like a cliff and you need drag radials to keep the ground in proper contact with the car, and.... it's just not a car for driving around any more.
    • I already reached that conclusion myself after reading up a whole bunch and watching various videos from multiple sources. Don't know yet how I'd best manage that with the least amount of headache. Probably pulling the sump and just welding on a AN10 adapter or something. I also think it's healthy to take most opinions with a grain of salt, because experiences differ wildly and especially Aussies - when talking about RBs - don't know a world below 600whp drag builds. Personally I doubt I will ever take my R33 racing, so it's going to be a street car with the occasional spirited drive. Hence why I am (so far) under the impression that I'm going to be fine with a stock-ish engine for a while.
