long story short, my turbo timer decided to switch itself back on without my knowledge.
moving the car around the throttle stuck wide open as id just popped it out of gear, so when i killed the ignition the bloody turbo timer kept it going.
looks like oil pressure dropped when it was revving nice & hard, & we all know what happens then.
motor still runs, but it makes nasty noises so ive taken to pushing it from 1 place to another to work on it. the last 2 butterflies are still being wedged open by something, im assuming inside the plenum as i cant locate any issues outside. when i disconnected the link to the main throttle assembly the rest snapped closed, so the issue is definitely in the rear 2 butterflies somewhere. il assess it when i strip it all down to clean & check.
shit go, but id just discovered it needed new gaskets & other stuff anyway....still, not the bill i was planning on.
now you guys get to read a longer build thread once its done lol :cheers:
  • 4 months later...
  • 3 months later...
bit of progress stripping everything apart, now i have bits everywhere.
once i get a good block prepped along with the r33 crank, the build shall begin
added some new wheels as well, aiming for better traction when it's running again
  • 10 months later...
ok so more detailed update after much time absent from the build thread
found the cause of the throttle sticking open....some little japanese bastard shoved a shirt in the intake that nobody ever saw, even after checking on 5 separate occasions prior to connecting cooler piping. i say some little japanese bastard because there's no way humanly possible either fatz or myself could fit in this tiny excuse for a shirt lol
fitted the 18" rims with wider rears aiming for better traction once the beast is running again
retrofitted an r32 GTR 320kp/h speedo to my already retrofitted gtr cluster
picked up an rb26/30 with the intention fitting the entire motor in place of my old sick rb26, but now thinking il just use the head which has been freshened up with 270 degree cams & several other good bits & pieces, then save the 3 litre bottom end to use with the original rb26 head for my cefiro when i get around to starting that (too many projects at once).
picked up some schmick flashy hks cam gears to help dial in the 270 degree cams when the rb26 is alive again too
also fitted a pair of turbosmart BOV's while things are all in pieces
1 last addition, not really noticeable with everything fitted to a motor, but the new turbos are now HKS 2530 items rather than the N1's, il probably keep them & rebuild them for an RB26/30 motor for the cefiro later in life
cheers
  • 4 weeks later...
here's the cefiro for the moment before work begins. initially il probably freshen up the old rb20 from my skyline & get it back on the road with that, while i build the 26/30 for a transplant at a later date. it's an ex drifter so probably got a few things to change for road use
    • I also think it comes down to the dollars spent for quality items, there's some cheapie versions out there, which look fine, but, there are versions of much higher quality out there, but, you obviously pay more for the quality of materials used and quality control When I first got work done by Advan Performance on my old R33 the silicone joiners were cheapies and actually blew out on a joiner heading to the plenum, when I then took it to Unigroup they said that the silicone hoses they used and were junk, Unigroup replaced every hose on the engine with much higher quality items and from then I never had a issue with any hose Additional cost and quality gets you quality silicone base materials and quality reinforcement fabric stuff As for OEM rubber hoses, again, quality materials and strict quality control will give you quality hoses, but only to OEM spec, I believe using quality silicone replacements is a upgrade I  saying this I have only dealt with vehicles I own and play with
    • Not gonna lie my sense of smell isn't the best. But it does look more grey to me. It doesn't smell like oil, friend says it smells like fuel.
    • That's it. Too rich for me. I'm out. If it does start to sell in pieces, I'll probably register an interest in the diff & axles, gearbox & tailshaft, and maybe the brakes.
    • I tried my best, well I see how it is though... It's time to be ruthless! I'll up my bid with a JVC sub and an amp to run it, 8 stainless steel drink coasters with a rubber backing, and a photo of Tom Cruise. Oh, I can increase the cash portion by 20 cents if that helps.
    • Or if it's grey, is it watery? Does it do it after you've been for like an hour long drive it will still do it, or just near the start of the trip? As GTS said, does it seem like oil (blue), water (white/grey) or fuel (black)? Sometimes the colour can be hard to see clearly too for what it is, as GTS says, what's it smell like?
