long story short, my turbo timer decided to switch itself back on without my knowledge.
moving the car around the throttle stuck wide open as id just popped it out of gear, so when i killed the ignition the bloody turbo timer kept it going.
looks like oil pressure dropped when it was revving nice & hard, & we all know what happens then.
motor still runs, but it makes nasty noises so ive taken to pushing it from 1 place to another to work on it. the last 2 butterflies are still being wedged open by something, im assuming inside the plenum as i cant locate any issues outside. when i disconnected the link to the main throttle assembly the rest snapped closed, so the issue is definitely in the rear 2 butterflies somewhere. il assess it when i strip it all down to clean & check.
shit go, but id just discovered it needed new gaskets & other stuff anyway....still, not the bill i was planning on.
now you guys get to read a longer build thread once its done lol :cheers:
  • 4 months later...
  • 3 months later...
bit of progress stripping everything apart, now i have bits everywhere.
once i get a good block prepped along with the r33 crank, the build shall begin
added some new wheels as well, aiming for better traction when it's running again
  • 10 months later...
ok so more detailed update after much time absent from the build thread
found the cause of the throttle sticking open....some little japanese bastard shoved a shirt in the intake that nobody ever saw, even after checking on 5 separate occasions prior to connecting cooler piping. i say some little japanese bastard because there's no way humanly possible either fatz or myself could fit in this tiny excuse for a shirt lol
fitted the 18" rims with wider rears aiming for better traction once the beast is running again
retrofitted an r32 GTR 320kp/h speedo to my already retrofitted gtr cluster
picked up an rb26/30 with the intention fitting the entire motor in place of my old sick rb26, but now thinking il just use the head which has been freshened up with 270 degree cams & several other good bits & pieces, then save the 3 litre bottom end to use with the original rb26 head for my cefiro when i get around to starting that (too many projects at once).
picked up some schmick flashy hks cam gears to help dial in the 270 degree cams when the rb26 is alive again too
also fitted a pair of turbosmart BOV's while things are all in pieces
1 last addition, not really noticeable with everything fitted to a motor, but the new turbos are now HKS 2530 items rather than the N1's, il probably keep them & rebuild them for an RB26/30 motor for the cefiro later in life
cheers
  • 4 weeks later...
here's the cefiro for the moment before work begins. initially il probably freshen up the old rb20 from my skyline & get it back on the road with that, while i build the 26/30 for a transplant at a later date. it's an ex drifter so probably got a few things to change for road use
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
