SAU-Vic Member.
Please confirm your attendance (either racing or spectator) so I can sort out catering requirements for the Squires Loft Nunawading BBQ! https://www.facebook.com/SquiresNunawading?ref=hl
Usual cheese/steak sambo's & skewers will be on the menu :)
In this time for this for sure.
SAU-Vic Member.
In for spectating and doing photo coverage for the day.
SAU-Vic Member.
I'm in!
Does anyone know the numbering of the garages well?
What is a rough number which is 2/3 of the way along when heading away from the tower? We've got enough people entering that we could book out 5-6 easily...
Once we've got a rough garage number I'll call up Brendan and book one for SAUVIC / BBQ / Home Base, then post it in here for others to book the surrounding garages.
I usually go as close to garage 10 as possible (starts @ #1 furthest away from the track entry) - keeps you away from the staging area mayhem.
Most SAU'ers were down the other end to me last track day so there may be a preference?
Guest
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
