1984 Nissan DR30 Skyline RS-X Turbo Tarmac Rally Car
Genuine RS-X Turbo Coupe, imported around 2000 by Just Jap Sydney and built to run Targa Tasmania 2001. After owner competed (ticked off bucket list) car was returned to Just Jap Sydney and painted in Bathurst colours and used as a showroom display car for the business. Seldom used since and bought by myself in 2011 to rebuild to LMS specs for Targa Tasmania 2014. We have an R32 GTR Tarmac Rally car also, can't keep them both so one has to go.
Link to R32 GTR add here:
http://www.skylinesaustralia.com/forums/topic/446104-1989-nissan-skyline-r32-gtr-tarmac-rallytrack-day-car/
Back to the DR30, car is as it finished TT14, specs at present:
Good standard and original strong FJ20 Turbo engine
Extended and winged sump
New Kameari H/D engine mounts
Light flywheel with button clutch and new Exedy pressure plate
RB20 high flowed T3 Turbocharger
Reco’d and modded radiator
New PWR intercooler and piping
Motec M4 engine management
2.5” exhaust
New VL Commodore H/D alternator
Rebuilt FJ20T gearbox with new Kameari C/R gearset for TT14
Reco’d tailshaft
R200 3.9:1 LSD rebuilt for TT14
Reco’d driveshafts for TT14
Koni yellow adjustable coilover shocks front and rear with new 350lb front and 275lb rear King springs
Kmac V3 strut tops
R31 25mm front sway bar
New lower control arms, ball joints and tie rod ends for TT14
R32 GTR front vented discs (296mm x 32mm) and 4 spot Nissan GTR calipers and Winmax W5 pads
Rear 280mm x 26mm vented discs with AP 4 spot calipers and Winmax W3 pads
Dual master cylinder adjustable pedal box and hydraulic handbrake
Hub adaptors and 8 x Genuine Skyline R32 GTR 16 x 8 rims (forged and very light)
4x 205/50/16 Yokohama AO50 med tyres (half worn) and 4 x softs (nearly new)
Body in very good condition with nill rust and works “Bathurst “ colour scheme
Very extensive full roll cage,
CAMS logbooked. Full QLD rego (320-STV) till 11/2014. Cage and seats Mod plated
Cobra Evolution winged seats and EGR 6 point 3” harnesses
Nav and driver footplates
Gell battery relocated in cab with kill switch
Alloy sump guard
Current car weight = 1160kgs, recent dyno at 160RWKW on 1 bar boost
SPARES:
Many standard trim, underbonnet parts, standard RS-X intercooler and piping etc
New unused Kameari adjustable Cam gears (cost $700)
Brand new fibreglass bonnet (save 20kgs and cost $1,600 ex Japan)
New unused DBA R32 GTR T3 front rotors and used F&R pads
Youtube footage from Targa this year:
PRICE:
$27,500 for complete package,
$25,000 car only
Ph: 0433 734455 -Paul
Edited by poolheaters
  • Like 1
  • 1 month later...
  • 6 months later...
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
