sup eeeeeeeevvvvvvveryy body
im a little bored and im after a little more response ! im currently running a gt3037s .84 rear housing and external gate on a stock r34 manifold. its making a tad over 300kw on e85.
i was thinking of changing the rear housing to a twin scroll housing ? don't know if its worth changing it to a .84 or a 1.06 twin scroll housing ?
or should i just buy another turbo :/
cheers
https://www.sau.com.au/forums/topic/446334-3037-with-twin-scroll-housing/
If you changed to twin scroll it would do these 3 things:
- Make boost a little earlier
- Not push you as hard in the seat when it does
- Cost a lot of money to do
My recommendation:
Replace the 3037 cartridge kit with a GTX3071 and keep your .84 EWG setup. Known winning formula.
Case closed!
  • Like 1
Leave it well enough alone the GTX3071 is not an upgrade IMO.
The cost of changing to TS is just not worth the effort.
Agreed, to do TS properly costs way too much.
This is pretty much what I did, changing the GTX3076 for the GTX3071, it was night and day for response, with very little loss in my case. If you can get a good price for the 3037 I would say go for it.
Do you want more power? Otherwise drop a GTX28 on there and run ethanol. Response and power. ;)
  • Like 1
I've only been in 2 GTX3071 powered cars, though have experienced a myriad of GT3076 and can say the GTXs definitely have the upper hand.
To the point, OP is asking about doing a twin scroll upgrade to get a little more response. Dollar for dollar I am more than confident that the swap to the GTX will get him the little extra zing he's after without the flatter feel.
Whether or not it is really a worthwhile change is as subjective and dependent on personal preference as can be, but I think the comment serves to answer the question.
GTX3071 is more of a sideways step IMO.
Slot a Forced Performance FP3076 into your existing exhaust housing....GeeTeeTee has proven back to back better response and power over his GT3076. Might be what you are looking for minimal changes and for minimal cost.
Link:
http://www.skylinesaustralia.com/forums/topic/426059-forced-performance-hta-turbos/
If you have your heart set on a twin-scroll setup (and prepared to spend the dollars) then I'd be looking to the Borg Warner EFR series of turbo's as these can be had in external or internal gate twin scroll form. Internal gate would save a lot of fabrication work.
FWIW here's an early graph of my 3071 TS .78 (s15) during tuning overlayed onto a tradition single scroll 3071 setup (on a different s15) which shows the more linear nature of a twin scroll setup which may go to some way as to why some may say they don't hit as hard compared to a single scroll setup.
Edited by juggernaut1
cheers
a tad over 300kw on E85? you must be running about 14psi or the tune needs more timing put in, that shouldn't be too boring at all, maybe it just needs another tune with more boost and
using a EBC to awaken the turbo more.
+1
A good EBC makes a world of difference. Going from gate pressure to now running an EBoost Street40 has made a remarkable difference to my car.
Refer post 140 showing a GT3076 with twin scroll .82 ex hsg on an RB....once again note the linear nature of the curve.
http://www.skylinesaustralia.com/forums/topic/269782-twin-scroll-vs-single/page-7
so what i gather is
its a waste of money going a twin scroll housing with a gt3037 on a standard manifold.
ill see more benefits if i go : FP3076
GTX3071
hypergear
do i sell my rear housing or do all above turbo cartridges suit ?
any other opinions oradvice ?
What you actually want is not clear other than "a little more response".
Bigger hp number? Stick more boost into it and tune.
Different torque delivery on boost, or spool characteristics? The FP turbo appears to be a good thing, retaining existing manifold/gate/piping. Split pulse might have the upper hand in lower/middle range rpm but you're into new manifolding, gate(s) and piping. Cost consideration.
More off boost torque and earlier transition into boost? There's no substitute for cubic inches.
so what i gather is
GTX3071
hypergear
If it were me, id take the turbo off and send it to Forced Performance for a 73mm comp wheel modification, cheaper and more effective result than Twin scroll and less work too.
Then you can join the HTA thread and brag about how good it is lol...
http://store.forcedperformance.net/merchant2/merchant.mvc?Screen=CTGY&Store_Code=FP&Category_Code=Turbo-Upgrade
Edited by AngryRB
  • Like 1
A few observations;
You want to retain standard manifold, have more response and hit 350kw. Cannot be done. Pick 2 of the 3 only.
Just to reaffirm my position.. Going to the twin scroll will make it the opposite of the 'more aggressive' that you are asking for.
Here are your two options based on the requests you are currently making:
1. Run E85 and max out the 3037 as is to get as close to 350kw as possible.
2. Swap to a GTX3071 core and run E85 to get probably 20kw less than the 3037 but a reasonable amount more response and possibly a little more punch.
  • Like 1
Subjective is it with any GT30 based turbo on a std manifold RB25 . Not quite sure what a 0.84 turbine housing is , typo 0.82 ?
My experience with the 52T version is that drive round power is very adequate but tuning even on E85 is critical in the rev/load ranges used every day . If the fueling timing spark is a bit how ya goin then it will feel lazy and it isn't necessarily the turbo causing it .
My take with the 0.82 GT30 hot side is that you can tune it to run better than with std or GT28 based turbos because the engine breathes out better and you can take advantage of that if you or your tuner tries . And this is with little or no boost .
I think it's a fact of life that you aren't going to get 10 pounds of boost at 2000 revs with one of these (first three gears anyway real world) and you wouldn't like it if could . But if you have an RB25 in good condition even a mechanically standard one it can be more than adequate on the street . The more I think about it many of their physical characteristics are the reason why they don't pull like a Patrol at 2000 revs and if you want all that's available small turbos aren't the way to go about it . The issue is can you make enough part throttle torque for your liking and can you accept that it won't pull like a locomotive till somewhere in the mid 3000s . If you want it all you have to have good tuning and absolutely the most accurate fueling injector wise you can get because I think it does affect the part throttle lowish torque .
I wouldn't have a 34 Neo Turbo without EV14s unless it was stock as a rock . To run E85 to 300 you obviously have different injectors and pump and they won't be small . Big injectors often struggle to spray well at low pulse widths and if yours is a dribbling mess like mine possibly is then the basic engine won't give its best at light loads and the pre spool area . Basically to me its how well you can get your engine to run up to the point where the turbo boosts and FI takes off .
A .
  • Like 3
    • Oh and my rear arms may need some attention too.
    • Bushings are almost done. Check the date stamp 😂 these are likely the original bushings with 27 years and 243ks on them.     Was too dark to get a pic of the worst one.
    • Porous blocks are a known issue on something like a Porsche M96, it's not really something I've ever heard of on an RB26. It's possible what people thought was a "porous block" was really a cracked block that they just didn't spot the crack on.
    • This is a controversial subject really, the whole power vs fun thing I mean And this is the main reason I got back into a MX5 Of the last few notable daily cars I've owned whilst I have frequented SAU R33 GTS-t: fun, but because I'm a idiot I modified well past a reliable fun car and ended up hating it, although that was my fault because I tried to have a daily cruiser and race car all in one, the family called it the sometimes car, because sometimes it was working, sometimes it was broken, gladly sold it NB MX5: brilliant car, thrashed the Bejebus out of it, but, again, was stupid and deleted the air con, power steering and stripped the interior out, whilst still fun, and reliable, and super cheap on consumables, it was not a fun place to be going on long cruises, I did love it, but basically every family member hated going anywhere in it, sadly sold it 2015 WRX STI: soulless thing that looked like your average Kia sedan and had that horrible boxer engine with glass ringlands, the family did like it though, that thing was one of my stupidest purchases and I still regret it 2017 Toyota 86: 😪 if I didn't crash it, I would probably still have it, it was a fun little thing, even with that horrible boxer engine, the family did like it, the only reason I didn't get another 86, or, BRZ was the boxer engine, I should have learnt after owning the STI, but I'm a idiot VX SS: great cruiser, fits the whole family, and was fast as.....in a straight line, but a big fat thing, so no enjoyment throwing it around corners, the family was unimpressed with the whole boganness of if, but they did admit it was a comfy place to sit on long cruises As for the NC, I feel it is perfect for what I want, or need out of of a car, whether I'm cruising the Hwy, back roads, twisties or peak hour traffic, the Mrs doesn't mind driving it either, or cruising in it as well, although she does bump her head of the roof nearly every time she gets in, which is farking hilarious, and the kids love taking it for a thrash as well So basically, I've had constantly more fun, and way less headache and heartache, both on the track and on the street, in low powered cars,  go figure.....LOL One thing though, the Mrs has stated that the cams have made the exhaust sound much louder, which they have, but it doesn't bother me, in fact, I actually like it, but, to negate any future comments from the Minister for War and Finances I may look at some changes to the rear muffler set-up to drop the volume down a tad to appease her when we are out and about in it
    • You will need to extend the turbo inlet pipe somehow, which could/might be done with silicone/rubber pipe, but might need steelwork, depending on your intake. And you will need to change the pipework on the outlet in teh same way, but this is more likely to need steelwork.
