Hey guys I installed my bee-r and it seems asif something not right, it doesn't pop or go ba ba ba ba it's more like baaaa and then the revs drop then baaa then the revs just drop and the car kind of goes quiet, what could this be? It's run right like once or twice but that's it, I think before I installed it my little shit of a cousin turned the knobs when I wasn't looking and I noticed that the knob can just keep on turning and not stop, do you think maybe that's something stuffed? On the installation diagram that I got from here says to connect the yellow wire to pinout 44 or 45 which one should it be on, I have it on pinout 44 is that, also it's popped engine fuse number 2 why could this be, by the way it's on my R34 gtt, any help would be greatly appreciated, thanks.
https://www.sau.com.au/forums/topic/446350-troubles-setting-up-my-bee-r/
Rather than coming here just to remind you BEE*R's are shit, ill shed a little bit of light
These are a pain in the ass to "tune" for the lack of a better word. You literally have to drive around hitting limiter over and over and over while playing with the little knob things
As for the yellow one (gain), adjust that one toward the right for more "bangs per second" or left for less; again for the lack of a better phrase.. - While the knobs keep turning, they do have limits in the software/code, so turning it all the way left for like 100 times will not f**k it up, it will just be at it's lower limit. try fiddling with this knob for more bangs. ALSO you will not spit fire and go bang bang every single time, it's quite random and sometimes will not make huge bangs, but sometimes will
To be honest, i have one in my 32, never use it and i would happily cut it out of my car if someone came over with cash
Thank god someone with a reply I'm looking for, when I turn it up its just a harder bang rather than more bangs, but I only turn it up for what's on the dial I think it was f? I'll try to just keep turning it and see what happens, thanks.
I would be very cautious in using that...
it's a hit & miss solution and you cannot accurately set the amount of retard vs. rpm
thus it's very easy to cook all your exhaust valves as well as destroy your turbo's exhaust wheel.
While I did try help, please don't discount the other replies
Using a BEE*R is a great way to destroy f**king everything, please take the other replies on board even if they are the exact opposite of what you wanted to hear
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
