Hey guys I installed my bee-r and it seems asif something not right, it doesn't pop or go ba ba ba ba it's more like baaaa and then the revs drop then baaa then the revs just drop and the car kind of goes quiet, what could this be? It's run right like once or twice but that's it, I think before I installed it my little shit of a cousin turned the knobs when I wasn't looking and I noticed that the knob can just keep on turning and not stop, do you think maybe that's something stuffed? On the installation diagram that I got from here says to connect the yellow wire to pinout 44 or 45 which one should it be on, I have it on pinout 44 is that, also it's popped engine fuse number 2 why could this be, by the way it's on my R34 gtt, any help would be greatly appreciated, thanks.
https://www.sau.com.au/forums/topic/446350-troubles-setting-up-my-bee-r/
Rather than coming here just to remind you BEE*R's are shit, ill shed a little bit of light
These are a pain in the ass to "tune" for the lack of a better word. You literally have to drive around hitting limiter over and over and over while playing with the little knob things
As for the yellow one (gain), adjust that one toward the right for more "bangs per second" or left for less; again for the lack of a better phrase.. - While the knobs keep turning, they do have limits in the software/code, so turning it all the way left for like 100 times will not f**k it up, it will just be at it's lower limit. try fiddling with this knob for more bangs. ALSO you will not spit fire and go bang bang every single time, it's quite random and sometimes will not make huge bangs, but sometimes will
To be honest, i have one in my 32, never use it and i would happily cut it out of my car if someone came over with cash
Thank god someone with a reply I'm looking for, when I turn it up its just a harder bang rather than more bangs, but I only turn it up for what's on the dial I think it was f? I'll try to just keep turning it and see what happens, thanks.
I would be very cautious in using that...
it's a hit & miss solution and you cannot accurately set the amount of retard vs. rpm
thus it's very easy to cook all your exhaust valves as well as destroy your turbo's exhaust wheel.
While I did try help, please don't discount the other replies
Using a BEE*R is a great way to destroy f**king everything, please take the other replies on board even if they are the exact opposite of what you wanted to hear
    • Well, I'm tired. I'm tired because about 4PM yesterday, before today's appointment someone immediately bought my bumper. They couldn't get it any other day as they're on the way back to NSW. So I had to do that big GTR conversion I had been planning. Unfortunately, the information on SAU about what you need and how this is done is incomplete. So what should be a simple bolt on affair, yeah, it's not. Did you know if you use all GTR items the bonnet won't close? This little manuever sent me into about 1am the night before trying to dodge a way to get it closed. I will have to revisit this in the next few days  - or maybe not, I may let a body shop figure it out. It all needs to come up and my motivation to pull the bumper off is low. It also seems to hit things in the bay where the GTT bonnet didn't. Yes I used 100% new OEM GTR items. Today, I had the joy of driving to the dyno looking like this: Given I had roughed in the fuel and given sensible but pretty conservative timing, I didn't really bet on having the car drive out any real difference than when it drove in. Sadly due to a miscommunication and laptop fun and games (and almost bricking the dongle, prayers and firmware updates indeed), I ended up using HP Tuner credits to licence the car that was already licenced. So in the end my laptop was used. It turns out my butt dyno is still well calibrated after all this time. The 325kw was on 74% Ethanol, the 313kw line was on 98. The other line is the 'before' line which was 281kw. While the numbers are pretty low, they're pretty in line with what you'd expect. Even if US dynos bump the whole result up about 50KW, gaining 10-15% is similar gains.  The curve of the cam is pretty much spot on with what was discussed as well. All this said, it still feels bad to not see the number you secretly want to see. Even if the car drove great beforehand, and I knew pretty confidently the car would drive out much the same way it drove in due to the nature of a wellish dialled in LS1 not gaining much if anything at all from being tuned from where it was. As expected, the car isn't particularly sensitive to running it at anywhere between 12.0 and 13.0 - And the initial timing at 20deg and 12.0 made 308KW. So 3 degrees of timing, and leaning it out to 12.7 for 5kw, anything above stopped giving any benefit until E85 (which has an additional 2 deg as before). Car itself behaved entirely fine. I found out that 100C = 1.15V! IAT at about 7pm was 19C. I might mess with the bonnet mounting.. but given the REO NEEDS TO BE CHOPPED TO FIT A GTR BAR this is possibly something I may leave gathering (more) dust until it returns to paint jail.
    • It sounds farrrrrrr too cold at your place Duncan... Here I was thinking our 10 degrees overnight is getting cold...
    • oh yeah, reminded this morning....bin lids frozen shut too
    • In my case not, because of total reno. But yeah.
    • Did you use an electronic speedo drive? Does you speedometer read all the way to 180km?
