Hey guys I installed my bee-r and it seems asif something not right, it doesn't pop or go ba ba ba ba it's more like baaaa and then the revs drop then baaa then the revs just drop and the car kind of goes quiet, what could this be? It's run right like once or twice but that's it, I think before I installed it my little shit of a cousin turned the knobs when I wasn't looking and I noticed that the knob can just keep on turning and not stop, do you think maybe that's something stuffed? On the installation diagram that I got from here says to connect the yellow wire to pinout 44 or 45 which one should it be on, I have it on pinout 44 is that, also it's popped engine fuse number 2 why could this be, by the way it's on my R34 gtt, any help would be greatly appreciated, thanks.
https://www.sau.com.au/forums/topic/446350-troubles-setting-up-my-bee-r/
Rather than coming here just to remind you BEE*R's are shit, ill shed a little bit of light
These are a pain in the ass to "tune" for the lack of a better word. You literally have to drive around hitting limiter over and over and over while playing with the little knob things
As for the yellow one (gain), adjust that one toward the right for more "bangs per second" or left for less; again for the lack of a better phrase.. - While the knobs keep turning, they do have limits in the software/code, so turning it all the way left for like 100 times will not f**k it up, it will just be at it's lower limit. try fiddling with this knob for more bangs. ALSO you will not spit fire and go bang bang every single time, it's quite random and sometimes will not make huge bangs, but sometimes will
To be honest, i have one in my 32, never use it and i would happily cut it out of my car if someone came over with cash
Thank god someone with a reply I'm looking for, when I turn it up its just a harder bang rather than more bangs, but I only turn it up for what's on the dial I think it was f? I'll try to just keep turning it and see what happens, thanks.
I would be very cautious in using that...
it's a hit & miss solution and you cannot accurately set the amount of retard vs. rpm
thus it's very easy to cook all your exhaust valves as well as destroy your turbo's exhaust wheel.
While I did try help, please don't discount the other replies
Using a BEE*R is a great way to destroy f**king everything, please take the other replies on board even if they are the exact opposite of what you wanted to hear
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
