Not sure if theres a thread on this already,
just saw that Shell is going to be bringing their own ethanol to Australia, they are using sugar can from Brazil..
Should create some good competition and ensure the longevity of Ethenol based fuel for us performance fanatics
Theres info on there page, cant seem to paste the link atm
Sweet. At the moment e85 seems to be a very niche performance fuel rather than an economical alternative.
Though why aren't fleets using the stuff where possible? Many new cars are flex fuel, plus you'd think government would or should have an environmental obligation if its a government run fleet.
Because the ethanol plants in Australia have already been shut down due to no support for the product
whut? they're were previously investing/investigating in lignocellulosic ethanol technologies only about 6months ago.
Bit of a scare tactic I think, to drum up government incentives.
I thought we worked out that plant is old and inefficient anyway, bring on solar distillation plants I say, then there will be no sooking about it's green fuel status. Should bring costs down too, not that we would see it at the pump.
Its true
the government is yet to decide but removing the grants given to those that produce ethanol is real and should be decided on soon.
If the grant is pulled then ethanol based fuels will die a sad death in Australia as its simply too expensive to import
I am also at a bit of a loss as to why Shell would be importing it when they are getting out of fuel in Australia
    • I ❤️ Matty I would like to thank Matty for going out his way in securing me a OEM NC detachable hard top for the NC Matty, your worth your weight in gold, and I cannot say how much I really appreciate your outstanding help I'll get it colour matched once I pick it up sometime in Dec-Jan 😁
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
