Hey all, Amir here
Finally found a decent base to start my modest track build. Bought her on the weekend, 1997 S2 R33 gts-t finished in QM1 and will henceforth be known as the “White Cloud”.
This will be a slow and modest build as I am relatively new to the track scene. Main objective with this build will be handling and modest power and above all offcourse is my and the car’s safety.
White Cloud came with the following:
Stainless Steel turbo-back exhaust with highflow cat (yes, because the fact that its shiny, blinggy stainless steel matters);
Splitfire coil packs;
Electronic boost controller;
Coilovers (JIC I think – will need to be changed);
Vented rotors at the front
Heavy duty clutch and lightened flywheel;
Wicked Sick 12” Subwoofer and Alpine Amp which were ripped out the day I bought it;
Nismo shift knob because stock shift knobs are for PU**IES my friend; and
A few other bits and pieces that add or subtract nothing to or from performance so who cares mentioning them?
On the short term to do list are the following:
17” rims (haven’t decided which ones yet, thinking of Stock R33 GTR/Enkei rpf 1) and semi slicks;
New racing brake pads, high boiling fluid and brake ducts;
New suspension and other bushes;
Return flow FMIC;
Upgraded fuel pump (walbro or bosch in tank);
A tune;
New alloy radiator;
Oil cooler;
Fixed back bucket seat and harness; and
Some other bits and pieces to get it track ready.
On the long term to do list are the following:
High flow turbo (keeping it as stock as possible);
Exhaust manifold;
Full strip and cage;
Aftermarket ECU; and
Who knows where it will end up.
Body wise I will keep the car as stock looking as possible. Lower it a bit, new rims and that’s about it really. The car is registered and I intend to keep it that way.
First thing I intend to do (well second considering the first thing done was ripping out the sub and amp) is take care of some rust beneath the bonnet just above the fenders. I will get stuck into that either tonight or sometime this week.
I will upload picture of white cloud and the work I do as I go. Watch this space.
Please Note: I do not have any of the items I intend to buy/install so if anyone has any of the items listed please let me know.
Cheers, Amir
https://www.sau.com.au/forums/topic/446405-amirs-r33-gts-t-build/
Did a little stripping on the weekend (to raise some cash for the build) and took out the stereo and all the unnecessary wires along with the rear seat, carpet and a bunch of other things. I think for now I will only strip out the rear half of the car and keep the front in full street trim. Will probably get some dry ice to remove sound deadener in next couple of weeks.
And now for some crappy iphone pictures....
Looks like a very clean car to be striped and turned into a track car.
Nice base to start with none the less.
Hey Michael. Its certainly a cleaner example. The interior is flawless and the car has been taken care off. That's why I intend to keep everything I take off the car and store it so that if I want to go back to stock then I can do that.
Cheers,
Amir
  • Like 1
Stripped more of the rear end tonight. Its now completely done. No point posting pictures of that. One thing Im unsure about is how to get rid of the sound deadener on the slopy bits (where the back rest of the back seat sits and near the wheel wells) by using dry ice. And Im worried that some of the wiring will freeze up and break. Any ideas?
I was given a nice 1kg fire extinguisher so will bolt that in sometime soon.
Still looking for suitable rims. I want to go 17" but for the life of me I cant find a set with all the correct dimensions. I was thinking something like 17x9 with 35 or similar offset. If anyone has any let me know.
Also looking for the parts in my sig (appart from oil cooler which should be arriving soon).
Cheers
Amir
very small progress. Finally found and bought the rims I want. 17x9 rota grid R. Now need to sort out tires.Thinking of going 245/40 but we'll see.
Also bought a Walbro fuel pump of a member on here.
I plan to strip out the sound deadening this weekend, install the fuel pump and if my oil cooler get here then hopefully install that too.
Cheers
Amir
Finally got the fuel pump sorted after much swearing and frustration. But its all wired up and working fine for now. They are a very noisy pump; especially with the interior stripped out.
Next on the list are tires, the oil cooler and return flow intercooler as well as stripping out the sound deadening and painting the interior.
Amir
Rota's are heavy and are knock off's. I would sell em and go for enkei rpf1 or r33 gtr wheels. Rolling weight is quite important. You are stripping the car of weight then adding weight to it by buying heavy wheels.
Semi's, do some research on here
http://www.tirerack.com/tires/surveyresults/surveydisplay.jsp?type=EP
Agreed on the rotas mate. Initially I wanted rpf1 but dont know how I ended up taking a different route. I think I will keep them for now and see how I go and later on get the rpf1 or 33R rims. Any idea how much they weigh? The Rotas I have are around the 8kg mark I think.
Cheers for the input
Amir
17x 9.5 16.7lbs Enkei
http://forums.evolutionm.net/evo-tires-wheels-brakes-suspension-sponsored-tire-rack/319078-weight-17x9-5-enkei-rpf1-sbc.html
18x9.5 wheel rota grid 22.5lbs
http://www.evoxforums.com/forums/showthread.php?t=47736
even if you added an extra pound to the 17" wheel it will still be around 5lbs per side difference. That is huge
Alright so I just found out my old lady has a pretty good camera so I took some photos of the car as is. Will upload better quality photos as I go.
Also got my oil cooler from a forum member, gave it a bit of a degrease and will try fit it on weekend.
Cheers
Amir
Did more work on the weekend. Starter stripping out the sound deadener with dry ice, it works really well. Most of the car is done but there are still a few more patches. Also had a friend install the oil cooler which is good.
Plans for this week are tires and intercooler.
Cheers
Amir
The oil cooler would scare me mounted like that, id be worried about about the possibility of some thing hitting those connections that hang low. I mounted mine up the other way so the connections were safe and mounted it high
I see what your saying. I was going to mount it vertically but my friend went ahead and did it this way while I was stripping out the sound deadening. There's plenty of clearance but if it becomes an issue I will mount it vertically.
Amir
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
    • Any damage to the box/input shaft?
    • Hey there Mate , I just got my local guy to install it Waterhouse Performance, Penrith (specialise Nissan/Datsun and other performance cars) , you can do it yourself if you like , AMS has instructions on their website.  Cheers Pac
