Hey guys
Currently I got a Maruhama something GPS Speed meter including Radar warner in my car. Well since that Alarm part is pretty illegal in Germany and the tool itself is pretty lower Quality, I am looking for a small Display which Shows me my current Speed. A really precise working one to be exact.
I do not want something like the Apexi RSM, just wire some power and done. I got so many cables still to check in my car, I really don´t Need additional....... ^^
Ofc I know the miled / km Thing, but some hints and tips would be great
Thanks a lot
https://www.sau.com.au/forums/topic/446442-gps-speed-display-searched/
Garmin do a GPS HUD that I was looking at a while ago (because I could get it cheap). Not sure if its what your after but it would only require power (probably has an inbuilt battery anyway if you didnt want to got that far even)
In the photo it shows speed/speed limit so its not the main focus when its navigating. I'm not real sure if you can get it to come up with speed when you arent navigating as the main item, but I think its pretty cool
Garmin HUD
Edited by 89CAL
Ye well actually I´m no frtiend of huds, really want an open front window. But thanks ofc for the help.
I do have a jdm navi in the car, maybe there is something that just gets the gps from the navi as kinda something like an add-on?
OFC I can´t use it since it´s completely Japan and so japanese maps, but would the gps care? Not sure about that :/
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that ne side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
