Keeping 300Kw On The Ground
Have you done a pressure test on your intake/piping? Cleaned your IACV and Cold start valve? -
Bit of a dump of ones I saw on my trip. I also have a heap from daikoko but that’s technically not on the street
i was thinking that the 2 wires that go to the sub from factory has some sort of preamp like you mentioned and also a lo Pass filter to get just bass. now that will only use 1 channel and that really should be all i need for a sub? if i was trying to put a set of speakers in the back i can understand cutting into the left and right speaker wires. i will try how im talking about doing it and if that is crap i will do it the way of all wires. thanks for the input guys.
By Equilibrise · Posted
Challenging mig welding thin Aluminium pipe and trying to fit it in, having to bend and twist, but got there in the end. Fits really well and can easily get a socket wrench in there now to put it on/off. I'm in the middle of another project, so haven't installed the suction pipe yet. I'll post some pictures and results when i do.
