Hey
Any suggestions?
I used to get all my alignments done at Adelaide Radial Tyre in Holden Hill. Tried calling today, lines dead, drove down and realised it's shut down...
Where are some tried and trusted wheel alignment joints?
I've got the standard setup, coilovers all round, camber tops front, camber and toe arms rear.
Did a few searches on here, found a topic from 2013 mentioning SA Motorsport Tyres and Kevin Kenny Tyres amongst others. Are these guys still worth visiting, or are there others worth taking a look at?
Also, roughly, what sort of prices would I be looking at from places like SA Motorsport Tyres and Kevin Kenny Tyres for example?
Thanks heaps for any help :)
Edited by rayj
https://www.sau.com.au/forums/topic/446446-wheel-alignment/
I had one done last week on a G6E Turbo by Tyrepower at Holden Hill - just a few doors down. They have good equipment, the guy knew his stuff, and he was very thorough - an "old school" tech. A wheel alignment (including a thorough bush/suspension inspection) was $65, plus $5 for some shims. I was very impressed with the service & happy with the price, so will use them again & happily recommend them. YMMV
https://www.sau.com.au/forums/topic/446446-wheel-alignment/#findComment-7358753
I have always used Bob Jane's at Prospect, on Main North Road. Clint, the guy who does the alignment has been there for a long time and certainly knows his stuff. Always have been happy with their service and price.
https://www.sau.com.au/forums/topic/446446-wheel-alignment/#findComment-7359324
go to the city branch and ask for him, he randomly rang me today for some parts.... talked for 20 mins about shares in gold haha. god the man can talk.
Yeah he can talk the ears off a rabbit mate.
https://www.sau.com.au/forums/topic/446446-wheel-alignment/#findComment-7362466
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
