It is not "better" and "more tunable".
Air flow meters measure the load directly. They are therefore actually a better way to measure load. They do have a few problems though, particularly with big turbo cars. These being a few age/reliability/dirtiness issues but mainly reversion from poor turbo intake design/execution. Particularly poor design/execution of the BOV return.
MAP sensors do not measure load directly. You need air temperature and a few other things (including engine speed) to work out what the load is from manifold vacuum. You also need to have a "model" of the engine's volumetric efficiency. In reality no-one has that model so MAP sensored ECUs are tuned using the engine as the model - ie you just add and subtract fuel to get the mixture right. That might sound trivial and normal, but in reality, if you then change something about the engine (say a freer flowing exhaust or something else that affects the VE of the engine) then you actually change the relationship between manifold vacuum and load, and hence the tuning changes. Might not be much, might be bad. This is why famously you couldn't just put bigger cams into many MAP sensored engines without them cracking the shits at you. You can do it with an AFM engine and it will probably still need a tune to get it really nice, but it will still get the fuelling pretty much right without much help.
So the choice between MAP and AFM for PFC tuning on Nissans is really one of taste and capability and what your plans for further mods might entail.
  • Like 1
gtr jet what would you suggest?
I'm only going with pfc because they're proven and the price suits me, I'm not willing to go all out on a haltech or anything like that, way too expensive for the power I'm chasing.
That's some good information GTSBoy, I'll keep it in mind, I'm really not sure what direction to take my car yet...
I was going to say a Haltech but they are a little on the pricey side. I run a PFC and it does what I need but if I had the money I'd upgrade.
If money is an issue then just stick with a normal PFC and grab a Z32 AFM.
AFM gives a 0-5v reading to the Ecu based on airflow (duh)
The z32 gives better resolution for higher airflow. The factory r33 Afms hit a 5v wall at around 220rwkw worth of airflow. The z32s go much higher, around 550 crank hp according to nistune
Where did you get the 400rwkw number from?
Is it a track car? because if its mainly street driven, you'd be better off running a little less power to make it more driveable
The D-Jetro makes it easier to setup intake pipes, run no/atmo bov etc. But as GTSBoy has said, the MAP sensor calculates airflow, where as a MAF actually measures airflow.
I'd suggest looking into a Link or Vipec. They will end up costing more then the Power FC but offer far more features and options for tuning. Keep in mind that this will mean you will have to change to MAP sensor (although not that bad, they have an inbuilt MAP sensor to get you started) and its suggested that you install an air temp sensor as well, which means you will need to fit it into the intake manifold or a cooler pipe near the throttle body. These arent major issues but worth noting. There will also be a small amount of wiring involved, but nothing to complicated
EDIT: The adaptronic as mentioned above I have heard some good things about, but having never used one I can't give any more advice then that
Edited by 89CAL
To put things in perspective.
D Jetro is worth say $1000? What's it gonna cost to pull the intake off, drill cylinder 3 and 4 runners for the MAP sensors positions and put it all back together. Let's call it $3-400.
L Jetro. Cost of ecu itself is $700 second hand. IF you need Nismo AFM's, let's call that $500 second hand or $700 new.
That's $1,400 either way
A Link G4 would be something around the $1,800 zone. No drilling, far more advanced ecu, can support things like ethanol sensors if you need it later on. (Never say never)
All of a sudden the old dinosaur FC isn't such "value for money" anymore.
  • Like 1
the power fc is fine...but the cons with the powerfc is that it doesn't have on board logging....but you have the handy controller which allows making changes without laptop, they are easy for tuners to tune.
just think about what your end goal with your car is....what GTSboy said is spot on...the MAFless ecu's take more time to tune properly as you have to do corrections that a MAF system will automatically do for you....
FWIW i started learning with a Powerfc and now i kinda wish i had a Link G4....hindsight is 20/20 if you can be patient and save the money then a link or equivalent that allows retention of MAF would be the way to go IMO.
I didn't realise 400rwkw was a lot, guess they're only 2.5ltrs, I've just come from the world of xr6t's where a reliable 400rwkw is less than 5k away lol.
I still have much to learn about skylines.
I might look into the link g4, ethanol is another thing I've put into the future and being able to run a flex sensor would be good.
Thanks for all the info guys.
  • Like 1
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
