Chrome paint is pretty crap, even the expensive cans lose their lustre very quickly when exposed to ... anything really... you can't sand it back for a smoother finish because you take away the chrome-ness of it and you cant spray clear over the top either because it does the same.
This is my experience.
https://www.sau.com.au/forums/topic/44645-chroming/#findComment-912409
If you want stuff Chromed, bring it to me, I'll take it to the people who chrome stuff for our machines.
The Chrome paint is bollocks.
It's cheapish to chrome stuff properly....
What are you chroming??
BASS OUT
https://www.sau.com.au/forums/topic/44645-chroming/#findComment-912423
Not that it really matters for interior bits, but remember that chroming does add signifcant weight (and it can also blind you with its bling-bling looks) :)
LW.
that extra 500g of paint will really slow the car down :)
for just interior bits just use a can of $15 paint with some decent primer underneath i say davor
hows adele (the missus) by the way?
https://www.sau.com.au/forums/topic/44645-chroming/#findComment-914165
this is what i did with chrome paint on my inside and i was fairly happy but 2GU UP 2 inside looks way better so now im thinking about getting them chromed
http://www.skylinesaustralia.com/photopost.../cat/500/page/1
https://www.sau.com.au/forums/topic/44645-chroming/#findComment-915034
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
