in need of some help... i was tapping into the two wires that go the the little light around the barrel and i had bumped the two together coursing it to arc out...
since then my light dose not work after i have changed the bulb and checked all the fuses and there was none that where blown, where do these two wires go as i was wondering if there is a fuse down the line or dose it go to a relay
i am now dumb founded and at ends with it frustrated and ready to burn it,
iv tried to track the wires but loose the after about 4' coz it goes into the big loom with all the ignition wires any help will be a advantage
P.S reason i was tapping into them was coz i was steeling the power to run my led floor lights as the light that gos around the barrel times out once the doors are shut
https://www.sau.com.au/forums/topic/446471-courtesy-ignition-barrel-light/
This may help:
the relays under the steering colum are where i would start if you can't find any blown fuse on the boards with the panel near the steering wheel. You may hear them clicking when you lock and unlock the doors.
Hi Ramstar,
Did you solve this problem? I had the same thing happen to me last night whilst changing cluster globes to LED's.
Changed the globes behind the instrument cluster & climate control unit & Gauge Pod..Blue looks awsum...But....
I went to investigate if the ignition barrel light globe could be replaced, accidentally broke the globe in the balast and now...no interior light nor map lights which worked fine previous to this.
I have tested all fuses in the interior fuse box - all fine. Also tested the interior dome light for power supply - none.
No power at the ignition barrel light plug either.
Wondering if anyone may have knowledge of any other fuses for interior lighting?
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
