Top Secret Imports co-owner Garry has offered a day out on the "Farm" next Fri 15th August, for SAU Members.
0406756477 is his number to register by Mon 11th.
Discount price of $500 includes instructor and full lunch.
Must wear full length clothing/shoes and helmet and fixed extinguisher. Membership card and Lic should be discussed with Garry.
Kind Regards
https://www.sau.com.au/forums/topic/446570-a-day-out-on-the-farm/
The pricing is reasonable. If you can swing it, do this! This is an amazing bit of road.
The one I attended they had rules about mandatory driver instructor in every car, every session. Keeps number of cars on the road VERY minimal. Not sure if this one is run similarly, if this is the same then that is a lot of instruction time!
Also check noise restrictions. The one I attended had guidelines about noise (hence taking the wife's 350z instead of the GTR).
    • Happy new years folks! Wishing you all a successful year of money pit ownership!  So the subframe bushes are out....   Ok, who else has done that job before??  What a C U Next Tuesday of a job that is!  Be glad to not do that again in a hurry! I think I explored every option available to chop the middle section of the bushes out, most of them unsuccessfully! I dried a holesaw, die grinder, normal drill bit, air chisel, etc, etc. The true success happened by accident when I'd decided to try a step drill I spotted on the bench on the way passed.  See, there are benefits to never cleaning up after yourself! It RIPPED through so so much better than the drill bit. It has to be the skinniest one available so its small enough to fit between the inner tube and outer casing but it made easy work of it.  First one i hammered the shit out of... New method- 20250102_185506.mp4     I did the other 5 in less time than I fluffed around with the first one. I used the cut off saw (sawsall as the yanks love to call them) to cut a break in the casing. Even with that they're still a prick to hammer or air chisel out.  The last few i just went rambo with the air chisel without cutting them. I overcome one of the early ones so will hit the with the mig to fill the cut then sand it off smooth.  The carnage left over-   I've also been "nesting" ie, cleaning up my babies nursery,  ie cleaning the f**king pig sty of a shed. I've got that much shit laying around it's as cluttered as my head!  Getting things put away, in boxes, on shelves, hanging off walls, all to get some working space back again.  Hopefully that keeps me motivated....
    • AFAIK does the base map for Haltech even have the 4D compensation enabled? It's been a while but when I looked at it I remember it was actually using pure TPS as one load signal and MAP for another. Seemed workable but not ideal by any stretch. A lot of people have "make the event-itis" which leads to stuff like this happening.
    • https://www.youtube.com/watch?v=qHhWelSBppY
    • Even back in the day, some importers were renowned for bringing in crashed cars, giving them a quick touch up + respray and making them look mint
    • No new updates from the op after covid, hopefully everything is ok...
