My '96 R33 gtst has recently started to run really rough when using headlights or winding the windows up or down.
At idle if the headlights are turned on or the brake pedal pressed the idle starts to hunt and when taking off it coughs and splutters like it's choking.
I have played with all the usual electronics and have found most cause the idle to hunt before regathering itself or if it's the headlights to constantly hunt and then intermittently run like ass.
Occasionally it will stall when coming to a stop using the brakes and clutching in. While cruising at say 80km/h and I wind the windows up or down or turn the headlights on it will splutter briefly until I stop using them.
I have used a multimeter to test everything and the battery is holding charge and not dropping in volts when the electronics are used so I am very confused. Also I have removed the IAC valve and cleaned it to see if that would help but that failed. It has brand new coilpacks and spark plugs gapped to .8mm and I am running an adaptronic ecu with map sensor.
Any ideas?
Any ideas?
Quick fix is to raise your idle a bit.
I'm sure somebody else has experienced this...
That might work however it would still run rough as shit in lower rpms as it is now wouldn't it?
Edit: Just read my first post and I think I forgot too mention that while cruising or in the lower rpm range not making boost it coughs and misses as well. It runs really rough until I start bringing it onto boost and then gear changes it feels like it loses all momentum similar to applying brakes a bit.
This only happens when using headlights or windows. So during the day it runs completely fine
Edited by KerrodR33
Have you checked ignition, fuel and air to make sure there is no issues?
If you want a walk through guide of what you need to do, I'll be more than happy to spend 10 minutes writing up a little guide. But I think you might be able to find some threads relating to similar issues. :)
Well as far as fuel and ignition goes it has brand new injectors, fuel pump and fuel filter and brand new plugs and splitfire coil packs installed about 2000km ago and new tune and all was working fine up until about 2 weeks ago. Checked for leaks and vaccuum leaks and haven't found any.
It really has only started happening since I replaced the alternator and didn't have any problems at first so maybe something wrong with that?
Although it's charging the battery fine and when I turn the headlights on there is no drop in voltage on a multimeter, only the noticeble changes in idle and driving behavior.
Sounds like the injector voltage offset is set wrong, the injectors take longer to open as the voltage drops. It would be a simple tweak for your tuner to sort out I assume.
Agreed. If it's electrical related check the earths, battery, engine, igniter and cas. Clean, sand and remount. Start here before you touch anything, especially if anything was played with from when the problem started.
  • Like 1
Cheers guys will have a look tomorrow and see if I can rule anything out.
And Scotty is there a way to check the Injectors with out taking it back to my tuner for this drop?
Edited by KerrodR33
Goto to the last few posts on the thread I linked below. I wrote up a small guideline to check injectors because that turned out to be my issue. :)
http://www.skylinesaustralia.com/forums/index.php?/topic/438150-Cylinder-%231-Dropping-Completely
Have you installed a Z32 AFM ? If so, some people earth it to the chassis near the AFM. Try connecting the two centre wires of the Z32 AFM together then connect that to the white/blue wire of your wiring harness. Obviously it is connected and running now but apparently with one of the AFM wires connected to the body it can cause bad running. See tutorial.
Let me guess, you're running an Adaptronic?
You need to set the base idle duty cycle too and set the dwell correctly vs. voltages or else you'll get all sorts of issues.
Also I find allowing up to 3 degrees of variable ignition timing on the idle close loop helps with all those issues
Yep lol I will mention this to the tuner and see if he can sort it out
Cheers
Edit: Also is it bad to drive the car when it runs into these issues? Currently on my corporal course for work and can't get to the tuner for a couple of weeks
Edited by KerrodR33
    • If you really don't want to touch anything you can try to trigger off the timing loop just to see if it's sparking semi-regularly. Don't trust it for actual timing measurements.
    • Also replace the fuel filter aswell today
    • Hey everyone, I have a r34 GTT s1, im having a problem with my skyline, ive let the car sit in the garage for the last couple of months and havent run it and ive gone to fire her up today and it cranks but doesnt fire, i have been having problems with it previously where it wouldnt start again after driving it around for a bit. It use to start fine on cold start ups but if you drove to the petrol station and fueled it up and went to go start it again, it would just crank and not fire untill you let it rest for a few hours, the car doesn't over heat it sits perfectly in the middle while driving when warmed up. Im thinking this problem has caught up maybe and now it just wont start at all. The car runs on e85, ive checked the e85 seems to be fine. I can hear the fuel priming before you go to start it and checked all my fuses and relays. List of things I replaced today - New battery - New sparkplugs - New Coolant temp sensor I was thinking about testing the CAS but from what ive seen online, if the CAS is cooked, the car will actually start up but then die instantly? as mine just doesn't fire at all. Does anyone have any idea or have encountered the same problems? thanks
    • Modern reg stuff now, they'd have a wide input range which would push through a buck converter, it would need to be able to maintain voltage for cranking conditions (sub 9V at times). Likely runs something like an internal 6V rail, and then further voltage regulators depending on which circuit/area it is feeding. Modern voltage regs, like what I'm starting a new power supply design with at work, will let me run a 5V rail output, and as long as my input is equal to or greater than 5V, I have a 5V output. Except I'm not pushing a 5V rail in our system as I don't need one, we're setting up for a 3.8V rail. Our new design will allow me 6 to 60VDC input, and everything else doesn't care, even when I start pushing a few Amp outputs.   Realistically, the voltage drop off could be caused by a few things though, one could be literally the alternator is dieing, and hence charge power is dropping, which also means on a straight hard pull you're starting to send the battery flat... (Not that likely from a single couple of gear pull if the battery was fully charged). However, having earth issues, like stray earths not connected, or someone having put a ground loop in, will see the ECU appear to end up with lower voltage "input", mainly because the "ground" is no longer equivalent to battery negative. If they're comparing the input voltage using sensory ground for example, and sensor ground is what is in that ground loop, than the sensor output voltage will actually start to be reduced, when compared to battery ground... Yeah, ground wiring design can start to be a bitch... Also voltage going weird from inductive loads not being managed properly is another real bitch... Hence, why I asked above about how everything was wired in. If OP knows, and can post all of the actual connections from the ECU pin out, as well as what wires are joined where in the loom, which grounds from the ECU have ground points and where they are etc. Would help to see if there is a ground issue. The part I'd start with though, is putting a mechanical oil pressure gauge on to confirm the theory. Otherwise the next track day when the threshold is lowered could result in another of @Duncan favourite types of jokes... Knock knocks... Pretty sure this is what @GTSBoy is also self high fiving...  Is all great that we have a decent theory... But they need to prove it before relying on it...
    • When I worked at BlueScope Steel, we had an Ethernet network, with every switch setup with a duplicate switch. Even when looking at all the primary switches, they had duplicate links, there was then also duplicated links between the primary in section A, to the duplicate in section B. So for each location that had networking, there was 8 network links. This was all back around 2007. That setup caused sooooo many issues, as many of those links were fibre. The network guys ran everything with Spanning Tree Protocol. And then we had great joy... The FOC Transceivers were slowly dieing, but in an intermittent way. And a lot of the time as they started to die, they'd drop offline for about 30 seconds... Spanning Tree Protocol was requiring 45 seconds to "rewire" the network... And by the time it was mostly finished, it had to start again as the transceiver was back online... Queue entire production network being constantly spammed with the spanning tree protocol messages...   My god I do NOT miss working in huge environments like that!
