Fantm 34 Posted August 9, 2014 Share Posted August 9, 2014 I've run into some trouble trying to get more lock out of my R34 gtt. Any help would be appreciated! So I've bought the driftworks geomaster knuckles and offset rack spacer and just installed them. I've had to cut 25mm of the tie rod and tap some more thread on it, also completely cut the original bump stop off but now the tie rod end is hitting the lca and still got a 1/4 steering to go to full lock. How can I get around this?? Any advice would be appreciated Link to comment https://www.sau.com.au/forums/topic/446603-cant-get-full-steering-lock/ Share on other sites More sharing options...
Fantm 34 Posted August 9, 2014 Author Share Posted August 9, 2014 Link to comment https://www.sau.com.au/forums/topic/446603-cant-get-full-steering-lock/#findComment-7361476 Share on other sites More sharing options...
White GTS-T Posted August 9, 2014 Share Posted August 9, 2014 This is why people notch and scallop the lca. But then you're going to run into binding issues. A bump steer adjustable tie rod end may help a little. Link to comment https://www.sau.com.au/forums/topic/446603-cant-get-full-steering-lock/#findComment-7361485 Share on other sites More sharing options...
Fantm 34 Posted August 9, 2014 Author Share Posted August 9, 2014 Okay thanks for that. Might have to start hacking away at it. What do u reckon binding issues will be? Link to comment https://www.sau.com.au/forums/topic/446603-cant-get-full-steering-lock/#findComment-7361497 Share on other sites More sharing options...
White GTS-T Posted August 9, 2014 Share Posted August 9, 2014 Before you do that, maybe have a read through this first http://www.nissansilvia.com/forums/index.php?showtopic=360823&st=0 Link to comment https://www.sau.com.au/forums/topic/446603-cant-get-full-steering-lock/#findComment-7361523 Share on other sites More sharing options...
Fantm 34 Posted August 9, 2014 Author Share Posted August 9, 2014 Hey will do thanks looks like a good thread Link to comment https://www.sau.com.au/forums/topic/446603-cant-get-full-steering-lock/#findComment-7361655 Share on other sites More sharing options...
Duncan Posted August 9, 2014 Share Posted August 9, 2014 umm I might be a bit old fashioned, but it looks like you already have more lock than the front end was designed for....do you really need more, more? Link to comment https://www.sau.com.au/forums/topic/446603-cant-get-full-steering-lock/#findComment-7361853 Share on other sites More sharing options...
Fantm 34 Posted August 11, 2014 Author Share Posted August 11, 2014 Funny you say that. I should have fit the wheel first cos I just got the bearing today and put the when on and it fouls out on a little bit of the chassis and the brake line mounting. I may have to look at getting different offset wheels to get around it. Link to comment https://www.sau.com.au/forums/topic/446603-cant-get-full-steering-lock/#findComment-7363049 Share on other sites More sharing options...
