Within a fully secure underground complex car park some prick has used what looks like a pick and hammer to try bust my lock out or a screwdriver. They never got into my car but the lock is completely totally destroyed.
I have an alarm, immobiliser and steering wheel lock that is always in a hard-lock position when parked.
Is there any way i can just replace the key hole with a metal plate or replace with a keyless entry door handle? This is the 3rd time - 1st in Newcastle, 2nd in Brisbane, 3rd now in Melbourne someone has tried to break the key/lock to get into my car..
Anyone got suggestions? Otherwise im over this car im selling it next week..
Unless it was your own personal lock up garage that only you have the remote/key for, I wouldn't assume it's "fully secure"... even if you had your own garage, nothing is ever secure. Anyone who can gain entry to the basement car park can physically get to your car.
R33 yeah.
Since i have alarm, immobiliser and steering lock fitted ive just removed the barrel key lock from the handle, covered it with a metal plate, painted it same colour as car. Only way they can get in now is smashing window or stealing my keys..
Hate these maggots.
Just FYI you don't need to smash the window to get into an R33. The windows have enough flex in them to pry away and get a coat hanger in there to flick the lock.
It's how my previous 33 was stolen, and also how RACV get in when keys are locked inside.
Passenger door?
disconnceted the locks on passenger door now too - its fully keyless entry.
f**ked if my battery goes flat, but at least less a chance of these maggots stealing my car.. i hope.
  • Like 1
haha fyi the r33 door unlock trick was covered about 9 yeas ago from memory
there was a how-to thread on how to disable it as well in the tutorial section, very old news
  • Like 2
What is the trick? just jam a screwdriver in and turn it?
So they had another go last night, now passenger door lock is ruined, drivers side door lock even more so than last week and now they jimmied the window scratching the f**k outta my window and ripping the rubber seals to pieces...
AGAIN didnt get in.. There goes about $500 replacing the seals and locks. :(
Getting really tired if your shit junky thieves.
wow.... that's no longer opportunistic dude, that's targeted at your car... I would either sell it or move it to a new location. Does your 'secure' carpark have CCTV? Have they audited the swipe access at all entry and egress points?
^^^ Good one mate now it's everyone's information. Hell of a lot of captains about to set sail!!
Old news. You can sometimes tell if an R33 has been broken into because the metal/trim above the window is creased from being pried open.
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
    • so I need a new speedo cable
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
