Within a fully secure underground complex car park some prick has used what looks like a pick and hammer to try bust my lock out or a screwdriver. They never got into my car but the lock is completely totally destroyed.
I have an alarm, immobiliser and steering wheel lock that is always in a hard-lock position when parked.
Is there any way i can just replace the key hole with a metal plate or replace with a keyless entry door handle? This is the 3rd time - 1st in Newcastle, 2nd in Brisbane, 3rd now in Melbourne someone has tried to break the key/lock to get into my car..
Anyone got suggestions? Otherwise im over this car im selling it next week..
Unless it was your own personal lock up garage that only you have the remote/key for, I wouldn't assume it's "fully secure"... even if you had your own garage, nothing is ever secure. Anyone who can gain entry to the basement car park can physically get to your car.
R33 yeah.
Since i have alarm, immobiliser and steering lock fitted ive just removed the barrel key lock from the handle, covered it with a metal plate, painted it same colour as car. Only way they can get in now is smashing window or stealing my keys..
Hate these maggots.
Just FYI you don't need to smash the window to get into an R33. The windows have enough flex in them to pry away and get a coat hanger in there to flick the lock.
It's how my previous 33 was stolen, and also how RACV get in when keys are locked inside.
Passenger door?
disconnceted the locks on passenger door now too - its fully keyless entry.
f**ked if my battery goes flat, but at least less a chance of these maggots stealing my car.. i hope.
  • Like 1
haha fyi the r33 door unlock trick was covered about 9 yeas ago from memory
there was a how-to thread on how to disable it as well in the tutorial section, very old news
  • Like 2
What is the trick? just jam a screwdriver in and turn it?
So they had another go last night, now passenger door lock is ruined, drivers side door lock even more so than last week and now they jimmied the window scratching the f**k outta my window and ripping the rubber seals to pieces...
AGAIN didnt get in.. There goes about $500 replacing the seals and locks. :(
Getting really tired if your shit junky thieves.
wow.... that's no longer opportunistic dude, that's targeted at your car... I would either sell it or move it to a new location. Does your 'secure' carpark have CCTV? Have they audited the swipe access at all entry and egress points?
^^^ Good one mate now it's everyone's information. Hell of a lot of captains about to set sail!!
Old news. You can sometimes tell if an R33 has been broken into because the metal/trim above the window is creased from being pried open.
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
